Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Print quality after changing both cartridges print quality seem washed out.
  • 2 more comments
  • fading star Nov 27, 2007
    have only printed 4 black and white pages (came out fine) and approx. 6 color photo prints (nice results there also), now every print is coming out very faded, even after running the "clean print head" utility several times!
  • Anonymous Sep 15, 2008
    print color is fading, when true colors are not there, but it is coming out pink
  • Anonymous Oct 22, 2008
    same issue
  • stevepolland May 26, 2009
    We have changed both print cartridges and cleaned the print heads several times. But we still get a very very light copy or blank copy.
  • 30 Answers
Your printhead might be dead. Call Kodak tech support and they will give send you a printhead with no charge.
Posted on Feb 08, 2008
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
Refilled my 56/57 ink cartridges on my 1210 all in one printer and even after aligning and cleaning it still has lines in it and is not the quality i need at all.
In that case, you better consider to but a new Genuine Cartridge, because it seems that some portion of your Cartridge nozzle got damaged.
If you still want to carry on with this refilled cartridge then try to print with Best Quality option enabled
Start >> Control Panel >> Printers and Faxes >> Select your printer and Right click then select Printing Preference . Here you can change print quality
Apr 09, 2010 | HP PSC 1210 All-In-One InkJet Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
Xerox Phaser 4510 laser Printing Quality
Hy, this problem is caused because the print cartridge is out of range. try changing with other cartridge from the other machinne. or buy another cartridge
Jul 17, 2009 | Xerox Phaser 4500 Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Print quality is so bad. Have renewed the
Dear Sueshpls,
Your problem's seem cause of printer head. You should change it . I face so many problems like that. So, pls take my advice.
Mar 22, 2009 | Canon S200 InkJet Printer
HP 840c Printer - Print quality problem.
I have no magenta trying second cartridge still same problem
Jan 14, 2009 | Apple HP DeskJet 840c InkJet Printer
Poor quality since changing ink.
If you didn't have this problem with the last toner than more then likely the new one is deffective. It seems to be having a ghosting issues which happens when the dr blade inside the toner does not clean properly. You need to try another toner cartridge.
Jan 07, 2009 | HP LaserJet 1022 Printer
HP Laserjet 4350dtn Print Quality poor
Most likely the fuser has lost part of the teflon from the heat roller. Having said that, the first step in any print quality issues is to change the toner cartridge. good luck!
Aug 26, 2008 | HP LaserJet 4350dtn Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
198 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
