Question about Dometic Rooftop RV Air Conditioner
Furnace problem I Have a 2005 Montana3295RK with a duo-therm air conditioner,suburban sf35f furnace and a dometic thermostat with remote. The problem lies with the furnace. It will not turn on, and in the rare event it does it will not turn off unless you either pull the fuse, turn the switch to the off position on the furnace or turn the gas off at the tanks. I can force the furnace to come on by pulling the fuse and then putting it back in and the thermostat does not have to be in the on position. By doing this if the propane tanks are turned on the furnace will run untill one of the 3 methods mentioned above are done.
  • gc349 Nov 16, 2007
    have a dometic 13.5 btu a/c hydroflame furnace. The furnace will notcome on at the heat /ac thermostat. Put it on the bench the furnace works. where coud the proble be?
  • 4 Answers
The problem is most likely in the control module of the roof air unit. Dometic uses the thermostat to activate and deactivate a relay in the control board of the roof ac unit whiich is just visible when you remove your air intake screen. The two blue with white stripe wires are the furnace control wires.
The furnace turns on and off by the opening and closing of relay. Most likely, the furnace control relay is stuck in the on position. On the thermostate, remove the fur wire and see if the furnace quits afrer it cycles down...it does not quit right away. With the termostat out of the loop, if the furnace does not shut down, the problem is in the control box. They are not hard to replace but you must be careful with the live wiire from the 110 ciucuit breaker. If you are not comfortable with the repair, take it to a dealer. The part number is on the assembly box. They need to know if you have the heat srip option or whatever othert options our Roof AC has. If the furnace still runs with the blue/white wires disconnected, the furnace wires are shorted somewhere between the furnace and the AC control unit.
Posted on Dec 10, 2007
SOURCE:
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
It is getting cold can you tell me how do i work the furnace part of my duo therm dometic air system
I hope this doesn,t sound patronising but i have seen people turn the themostat down to make the furnace come on obviously the thermostat has to be turned up to set for a higher tempreture , after a small time delay, should then light up.
Oct 20, 2011 | Dometic Rooftop RV Air Conditioner
My dometic duo-therm thermostat is no longer showing an option for my furnace.
I assume it's remote control. (comfort control) Have you tried following procedure for selecting "Mode"?
Nov 06, 2010 | Dometic Rooftop RV Air Conditioner
Dur-therm furnace heat controll with Dometic remote
i would suggest that you look at your thermostat,it may be to close to the furnace keeping in mind that all thermostats have a certain tempreture drop (or gain) before restarting john
Dec 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
994 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
