Question about Philips Magnavox 27MS343S 27" TV
Magnovax tl712 c107 model #
My mom gave me this philips magnavox w/o remote. i cannot get the tv to go past channel 35 and cannot enter the tv menu to search for channels. tv chasis model # is 27b700-7562
  • 398 Answers
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Posted on Aug 22, 2007
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
Philips magnavox tv, no remote....channels locked
I called Philips at 1 888 744 5477 and they solved my Access Code question thusly.
Default Code is 0711.
Hope I can submit this now, AND that it helps someone.
Jan 30, 2009 | Philips TP2784C TV
15-1931 NEED INSTRUCTIONS FOR A MAGNOVAX T.V.
If you mean Magnavox - try these - Magnavox 1454, 0054, 0030, 0706, 1913, 1904, 1931
Oct 23, 2008 | Radio Shack (15-2147) Remote Control
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Televison & Video
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
premtech@willapabay.org
Nov 17, 2007 | Philips Magnavox MS3652S 36" TV
AV channel on magnavox tv
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Nov 05, 2007 | Philips Magnavox 13MT143S 13" TV
Vert adjustment
To enter the service menu (use the button on the set)turn on the tv, then turn it off, using remote enter 2, 7, 1, then mute with in 5 seconds. Then press 9 and select V-S, display chnages from V-S and V-P. Then use channel up and down to adjust. When down use the power on the set to turn it off.
Apr 11, 2007 | Philips Magnavox 20MS233S 20" TV
Philips Magnavox 27MS343S 27" TV Logo
285 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
