Question about Canon BJC 2100 InkJet Printer
Colors are not the same as are on the screen - Canon BJC 2100 InkJet Printer
  • 30 Answers
Are you using the ORIGINAL INK? What's media color are not same? For example, photo, document or others. May i know, what display device you used?
Posted on Aug 23, 2007
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
Sep 19, 2013 | Samsung Televison & Video
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The colors on the screen are not right, even when ...
If the color controller (color circuit) is failing, the true colors, detail and density will be erratic. A professional technician can trace the circuit and diagnose the problem in minutes.
Feb 01, 2018 | Palm Tungsten E2 Handheld
There is no Gray, it is Green gray. Photos are not what is seen on screen, Need calibration or something.
The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver.
For most users, the best method for matching colors on your screen to your printer is to print sRGB colors. The printer uses sRGB and automatically optimizes color output.
Dec 05, 2009 | HP Color LaserJet 2600n Printer
Screen color
It's not a color screen so no, you can't change the color. You can, however, change the contrast. Press and release the 2ND key, then press and hold the up-arrow to increase or down-arrow to decrease the contrast.
Sep 23, 2009 | Texas Instruments TI-85 Calculator
DVD player car screen plays dvd in B/W , navigation in color
try checking the color system if its ntsc or pal
Jul 11, 2009 | Car Audio & Video
Color Display problem
it seems that problem that ur facing is manly related to drivers but try booting into safe mode and incase ur screen look normal in it try installing the driver from support.dell.com.or check in bios and check the screen in case ur screen is still bad then contact dell
Feb 03, 2009 | Dell Inspiron 1501 Notebook
I have a 42 flat screen projector. The picture i see doulbe the normal color of the letter. then behind the letter they show up in different color. Then when there people on the screen or object there...
The colors have to be aligned most systems have a calibration screen with in the setup menu
Follow the instructions .... this is a common issue
LB
Sep 21, 2008 | Televison & Video
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Canon BJC 2100 InkJet Printer Logo
23 people viewed this question
Clive
Clive
old marine
old marine
