Question about Echo Indigo Stereo Output Device for Laptop Sound Card
Output problem on DJ soundcard
I hear the same thing in both of the outputs. I have changed all of the settings that we were using and it worked fine. All of a sudden the sound starts coming out of both outputs. Any ideas?
    Novelist:
    Champion:
  • 382 Answers
Have you recently upgraded any part of your hardware, software or operating system? I had one of these for a powerbook 3 years ago. And i used the software monitor to control the output busses, but Believe 1 is intended for monitor out, and the other for main out. So, ideally unless your processor or sound generating application can handle sending 2 separate signals, 1 to each out ( like serato or torq ) that is normal operation.
Keep me posted.
Posted on Dec 16, 2007
SOURCE:
I am a trainee dj and the pc I am using plays music through the USB port and then a sound card the volume changes on some tunes and I have to keep composating it with the slide controls
no two songs have the same output, using iTunes with their "even output" setting may help, Virtual dj has a limiter control as well if u are using virtual dj pro
If you need further help, I’m available over the phone at https://www.6ya.com/expert/ernie_b93ee48ba0eab50b
Oct 01, 2013 | Computers & Internet
I cant get my headphone to work on my gemini cntrl-7.
If you are using virtual dj , adjust your settings under configuration - sound setup , change the output settings to headphones.
Jun 08, 2012 | Gemini DJ Gemini CNTRL-7 USB MIDI DJ...
My ion discover dj decks worked fine until i tried to use an external usb sound card alongside it for the headphones, now, even with the usb sound card removed,i am unable to have 2 of the audio outputs as...
i would do a uninstall of anything Made by ion and Re install and see if that solves your issue, Ion isnt a very good dj product so something as simples as this could screw something up. try a fresh install and please let me know what happens and ill assist you from there
May 15, 2011 | ION Audio Discover Dj Turntable
Well i have a numark mixtrack with a dj-io soundcard. but i use a regular computer and not a laptop. my thing is i've seen these videos on youtube to try to connect it but it doesnt help. i want to be able...
if your desktop has two audio outputs (one for headphones and the other one to connect the speakers - both green), then you dont need dj io (or a second sound crad on the side), just go to config and chose the sound card settings to double inputs and in outputs chose both speakers and headphones' depending on what software you are using.
questions [email protected]
Nov 13, 2010 | Numark DJ/iO Sound Card
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
Ringing sound in background
sounds like there is a input to output loop of some kind. On some of my soundcards I was able to configure a virtual patchbay. Check around in the software for this and macke sure outputs are to outputs and ins to ins. Good luck.
Aug 28, 2009 | Rane Serato Scratch Live Computer DJ...
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
How to hook up a boston acoustic ba7500g speaker
you can connect the BA7500G speakers to a regular digital coaxial output by using a cable that has an RCA plug on one end and a stereo minijack on the other. However, the pole of the RCA must connect to the tip of the stereo minijack and the shield of the RCA must connect to the middle ring on the stereo minijack. Also set your soundcard to output at 16bit and 48khz.
Oct 19, 2008 | Acoustic Audio Players & Recorders
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
Echo Indigo Stereo Output Device for Laptop Sound Card Logo
Top Echo Computers & Internet Experts
Ekse
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you an Echo Computer and Internet Expert? Answer questions, earn points and help others
