Question about Kodak EasyShare DX7440 Digital Camera
Battery lock I broke the battery lock while trying to insert the battery. I brought it to a camera repair shop who said that they are encountering problems getting spare parts for this camera and especially a replacement lock. I live in Dublin can anybody recommend another camera repair shop that may locate or have the part. It is only 2 years old.
    Problem Solver:
  • 28 Answers
If you can’t find a fix there is a guy in South Carolina who sells good used parts. I bought a LCD from him for $39.00 and it works great. I think his email is gerald.ray@aa-ark.com
Posted on Mar 08, 2008
    Genius:
  • 2,985 Answers
Probably not. Parts for digi cameras are notorious for non availability The general feeling is it seems that among certain brands and model levels they are considered 'disposable' like computer parts, kettle and toasters. Adhesive or gaffer tape would seem to be the answer.
Posted on Aug 21, 2007
Camera can turn on a moment than shut down
1) clean the contacts battery very well
2) using wrong battery type, use alkaline only
3) batteries inside with polarities wrong
4) batteries with insufficiente voltage, insert GOOD BATTERIES
5) see the memory card is inserted in securely closed.
Try it.Otherwise if the problem persist , problem with power supply +Syscom circuit associated., go to the repair shop for fix it.
God bless you
Sep 22, 2012 | Kodak EasyShare M380 Digital Camera
My Av100 digicam is always lowbat but the batteries i've inserted is full charge
Try to buy a new battery. If the problem still persist, there a hardware failure to your camera. Bring it to camera repair shop as soon as possible.
May 06, 2011 | Fuji FinePix A340 Digital Camera
On attempted power-up, camera begins to start up, then gives off three beeps and shuts down.
Check your battery condition and see if its full charged. If you pass this step, check if the battery is seated correctly in its place. Try to power on the cam with a DC connection and see if its doing the same symptom. If after this step you encounter the same problem, get your card out and try to start it without memory card, If again the problem persists, try to check it at a professional repair shop for a possible defective board. Cheers
Dec 10, 2010 | Cameras
I've brought a usb cable to charge this camera, and it still doesn't work. I've tried everything except a new battery. I dont wanna buy a batty and that isn't the problem
Did you try a charging cradle? If you know how to use a voltage meter you can check the battery yourself or have you local camera shop or battery shop such a as batteries plus check it for you.
Dec 06, 2010 | DCS Norcent Technologies XIAS DCS-1050...
Card error
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 06, 2010 | Olympus E-1 Digital Camera
When I try to insert a memory stick into my sony cyber-shot dsc-p20 it won't lock in place and I can't close the door. Help!
Try quickly pushing the card in and letting it go, fast. Keep trying this and see if the card finally locks, you could have a build up of fluff on the latching mechanism. doing this could free the fluff and problem solved.
Its also possible that the latching mechanism has dislodged which means a dismantle at a repair shop.
Apr 10, 2010 | Sony Cyber-Shot DSC-P20 Digital Camera
Will not power on
It should power on using internal memory. Your problem is normally due to weak/dead batteries. Make sure that you have fresh batteries, or freshly charged batteries, installed. If changing the batteries out does not eliminate the problem, the camera is a likely candidate for the repair shop.
Bill B.
San Antonio
May 12, 2009 | DigiLife DDV-C330 Digital Camera
Repair Casio Exilim EX-S500 Battery Lock
Hi you can go back to the casio repair centre to get it done. Mine actually broke off and it was repaired within half an hour :)
Mar 16, 2008 | Casio Exilim EX-S500 Digital Camera
Flashing lights
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Feb 17, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Kodak EasyShare DX7440 Digital Camera Logo
124 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
