Question about Dell 3300MP Multimedia Projector
New lamp/ LAMP FAILURE
When it comes on it flashes Standby then when you turn it on it says warming up, then it says lamp failure. we just replaced the bulb & still the same problem.
How did you get the cover off and was it the top or bottom cover?
Posted on Jan 30, 2009
Mine did the same thing, then I took the cover off and found the main circuit card loose. Pushed it back together and it works fine now.
Posted on Jan 31, 2008
I replace a new Philips bulb on my HL-R7178W and still not light up. It has humming noice (not hi pitch) and clicking like on and off and the Standby/TEMP and LAMP lights flash 2-3 times and turn off. The...
Hello... I would start by getting the correct lamp for the TV, and I would advise getting an original equipment lamp. The lamps and ballasts are matched by wattage and operating voltage, and a mis-match will at best cause early lamp failure. The sound you are hearing could be the ballast trying to ignite a bad lamp caused by a mis-match. I hope this helps!
Nov 25, 2017 | Samsung HL-R7178W 71" HDTV
When powered on, the green standby light continues to blink until it eventually turns red and the cool down process begins. The set top box is powered on but the picture never comes on.
The most common cause of No Picture - Lights Flashing, or Intermittent Picture - Picture Cuts Out in all Sony LCD TVs is bulb failure.
No troubleshooting or replacing parts should be attempted without installing a "known" good bulb. This is not a fault, the mercury in the bulb has been consumed.
Many dollars are spent on parts and service when the only problem is bulb failure.
You can replace the complete Lamp Assembly or the Bare Bulb. DIY or get a serviceman. Here is a link that shows how to change or replace the bulb or lamp in Sony KF50WE610.
Sony Lamp, Bulb, Installation Guide
Dec 19, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
TURNS ON THEN FLASHES GREEN FOR ABOUT A MINUTE THEN KEEPS FLASHING RED .WHATS WRONG?
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
Sep 30, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Panasonic pt-50lc13 it just will not turn on,but the red light is on and the lamp was replace
Is the lamp indicator light flashing? A new lamp may not solve the problem. The known problem with lamp failures is poor voltage output from the ballast,.. a problem Panasonic refuses to correct and they decided to no longer provide the repair part through their supplier in an attempt to sweep this problem under the rug.
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Problem with tv turning on and off
Does the green light begin to flash when the picture disappears? If so, you have a weak lamp causing your TV to shutdown the picture. Replace the lamp with an original Sony lamp as the aftermarket lamps are known to have problems such as early failure and low brightness. Please be sure to rate this solution. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
LG dlp rear projection Tv model 56DC1D. When switching on the yellow light flashes for about 2 minutes then the red lamp light flashes twice before switching back to standby mode. The TV is approx 18...
First, check if any of the vents are clogged with dust. If not, try another lamp. They don't always look bad when they are bad. If you feel handy, by the lamp itself without the cage and swap in the new lamp. Make sure you do not touch the new lamp (finger oil is bad for the lamp. The oil creates a hot spot and early failure).
Nov 06, 2008 | Televison & Video
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Dell 3300MP Multimedia Projector Logo
718 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
