Question about Garmin StreetPilot i3 GPS Receiver
No address option in where to Menu
My i3 does not show the address option in the where to menu, so i can' enter a postcode/zipcode. How do I reset it or download new software from scratch?
  • ylautan4 Nov 20, 2007
    The drop down menus in "Where To" in my i3 doesn't come up, so I cannot enter the address of my destination. How can I fix it?
    Problem Solver:
  • 10 Answers
I find the zipcode quit useless becaus you can only enter the first 4 numbers (netherlands) so you also have to lookup the street. you can get the new release best with the webupdate: http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Posted on Oct 04, 2007
SOURCE:
What is the zipcode for New Zealand
New Zealand has multiple zip codes or postal codes. The New Zealand Post website should be able to help you figure out the zip code for the exact location you're looking for in New Zealand.
http://www.nzpost.co.nz/tools/address-postcode-finder
Hope that helps!
Nov 16, 2012 | Computers & Internet
Can't connect to router by wireless and by local area connection with cable, it just saying limited or not connectivity, even after router reset.
Locate the MAC Address for the Computers You Want to Use for Gaming
1. Click the Start button.
2. Click Run.
3. In the Open box, type the following text:
cmd
4. Click the OK button.
The command prompt screen appears.
5. At the command prompt, type ipconfig /all
6. Write down the MAC (Physical) address of your computer to configure for gaming.
Change Router Settings
1. Open a web browser, and type http://my.router, or http://192.168.2.1. The Enter Network Password login prompt appears.
2. Type the following text in the user name and password fields: "admin".
3. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
4. Click the DHCP Server Settings menu option in the drop down menu.
5. Click the Add button in the IP Address Reservation section.
a. Enter the MAC address of the computer you wish to use for gaming in MAC Address field.
b. Enter an IP address for the computer.
6. Click the Submit button.
7. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
8. Click the Port Forwarding Settings menu option in the drop down menu.
a. To set a single computer for gaming, click to select Enable DMZ Host.
b. Enter the IP address of the computer in the DMZ IP Address field.
c. Click the Submit button.
NOTE:
Only a single computer can be set for DMZ service. To set multiple computers for gaming, please refer to the Custom Port Forwarding Settings under Port Forwarding Settings.
9. Reboot the client computer. The client computer will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
Oct 28, 2010 | Dell Wireless 2350 Router
What is zipcode can i know what is zipcode?
In America it is called zip code. In Australia and UK, Postcode. It is the last few numbers and/or letters in your address that tell the post Office computers where to send your mail when it is hard to read the rest of the address. Basically it gives exact location of your local Post office.
In Australia it is four numbers, First one is state, and so on.
In US it is 2 letters giving the state and then numbers, in Uk it is 2 letters, 3 numbers 3 letters, etc.
Apr 30, 2010 | Avon Healthy Remedies Bath Necessities...
How do i set the ip address on a AR-405
Depending on the interface option set up in your copier, you will either access the printing setup options via the Custom Settings option, then enter the Key Operator access code to view the expanded menu or you can press the 'Copy' button to the left of the LCD screen and look for Main Menu options, then make sure you've enabled TCP/IP (You may have to reset the copier in order to enable it). You should be able to enter the IP address manually.
Sep 18, 2009 | Sharp AR-275 Copier
Recently updated TomTom GO 300 now it doesnt show the postcode and street name together like before. Now when you put in postcode, it gives a town instead of the street name on the same line. Then all I...
I have just updated my TomTom GO 300 and now encounter exactly the same problem, I have gone through all menu settings and can't find anything linked with this???
Jun 27, 2009 | Tomtom ONE 3rd Edition GPS
Changing home address
  • Tap the screen to bring up the menu
  • Tap the 'Change preferences' icon
  • Tap the arrow to the right to the 'Change home location' icon (looks like a house with a spanner)
  • Choose the best option to identify your address (postcode, address, recent destination, etc)
Dec 27, 2008 | Tomtom One XL GPS Receiver
We have a problem putting in names and addresses.
All tomtoms are more or less the same. You tap the screen to make selections.
Switch on , let it boot up / Tap the screen / Then tap " Navigate to" / then tap "address" / Then tap either "City centre" or " Street and House Number , or Postcode " ( you select one of these by tapping screen ) . Lets say you just tapped "Postcode" . A keypad will appear on the screen for you to enter a postcode. NOW, enter the postcode ... as you enter the postcode , streetnames will appear and you can either continue to enter the postcode OR you can choose one of the street names that appear. Once you have done this , the tomtom will ask you to select a "house number" . if you don't know the number then just 'try' selecting number 1 . Once you have done this , select "Done" and the tomtom will switch for that screen to the "route calculation screen" . if you now tap the screen once more your tomtom will start giving you direction both visual and audible , to your destination . ( you must begin to move before it will start ) . ....................... Once you have completed the journey , you can now cancel the navigation by once again tapping the screen , then use the "right arrow icon" to move through the menue screens. When you see an icon with a RED CROSS through it , and underneath it says " clear route" , select that by tapping and the route / navigation will be cleared. ... Good luck , hope this helps.
Nov 27, 2008 | Tomtom One XL GPS Receiver
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Garmin StreetPilot i3 GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
