Home | Epson | Stylus DX4200 All-In-One InkJet Printer | Communication error
Epson Stylus DX4200 All-In-One InkJet Printer
Problem for Epson Stylus DX4200 All-In-One InkJet Printer
Communication error
By brammozz on Mar 24, 2009
my epson dx4200 won't print anymore when I do a status check it says communication error. I checked cables turned it off and on reinstalled the drivers nothing helped.
copying still works as it should
solution anyone?
thanx
Comments:
Mar 24, 2009
- tried a new cable still the same
i get a notification that i branched an usb device on the computer.
In the device manager there are no exclamationmarks but I reinstalled the driver anyway. Setup didn't find the printer so I had to manuallyselect usb printerport.
rebooted
But still same problem
I think something broke in the usb connector in the printer
Solution #1
posted on Mar 24, 2009
Somewhat Helpful)
ronenfe
Rank: Guru
Rating: 87%, 85 votes
when you connect the printer to the computer, do you hear a sound or see a notification that a device is connected?
if not , i would try a different usb cable, or try a different usb port.
if you do , then it's probably a driver problem, check control panel,system, device manager, hardware, and see if you have an exclhamation mark on the printer, if you do, try to reinstall the driver.
Comments:
Mar 24, 2009
- check the pins inside the usb connector in the printer, if they are bended try to straighten them with a litlle screw driver.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus DX4200 All-In-One
Questions and Unsolved Problems for Epson Stylus DX4200 All-In-One
Do you recommend Epson Stylus DX4200 All-In-One InkJet Printer?
Answer
Answer
Compatible cartridges still have lots of ink in them (I can hear it swooshing about) but printer... (More)
Answer
I downloaded the driver for epson stylus dx4400 and only the scanning works i would like the printer... (More)
Answer
I have an EpsoN DX4200 that will not scan, I have reloaded from the original disc three times now,... (More)
Answer
I have an Epson dx4400 and some time ago the heads went out of alignment. I have spent at least... (More)
Answer
Dx4400 Keeps displaying 1x empty cartridge, although cartidge is New. Needs printer resetting. Any... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus DX4200 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
