Question about iLO (2 GB) MP3 Player
Problem after problem with MP3 player
Now my MP3 player after a song finishes it just shuts itself off. Then when I turn the on/off switch off and then back to on it just says "starting" with an hourglass and nothing happens. It does this too when I plug it into my computer to download songs.
I can't get it to turn on, I just got it yesterday?
Posted on Dec 27, 2007
Comes on then shuts off
Sounds like your battery may be at fault, or if you rely on the usb to charge, then maybe it's not charging it due to power settings on the pc.
Try charging from the mains without the player being turned on, for about 20-30 mins. Then turn on and if the problem is still there, then it's the battery.
Jun 18, 2009 | Philips GoGear SA3020/37 MP3 Player
My Sansa e250 won't stay connected or sync
haha your welcome. good luck with your mp3 player in the future!
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
Navagating music files on mp3 player
no, actually, you can't. it leaves off on the song you finished listening to after you turned it off. i know it's irritating, but you just get to listen to your songs in the order that you put them in.
Aug 09, 2008 | Coby MP-C883 MP3 Player
Songs go into a scattered order.
It is possible that the memory or settings have been corrupted. Install and run the Philips Device Manager from the product CD.
Select the restore / repair option and follow the on-screen prompts.
This will re-install the firmware and format the player.
When the process has finished, restart the player. It will initiallize and then shut down again. Switch on again and you'll get an "updating" message. The player will now be empty. This should also cure the alphabetical list problem.
Feb 15, 2008 | Philips GOGEAR SA6045 MP3 Player
Random Shut Off and On
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 30, 2007 | iLO (2 GB) MP3 Player
Starts to turn on, then powers right back off
I had the same problem and had to return it and got another. I'm know having more problems,,, going to return and get $$ back. Good luck
Aug 16, 2007 | iLO MP3 Player
My Sansa turns off by itself...Help?
This happens to me to but only when Im listening to a long playlist and I haven't switched anything in a while, but if you go to "settings" and the to "auto shut-off" you can set the time you want it to auto shut off, usually it is on 5mins, so when the 5 minutes are up that you haven't touched it, it will shut off, i belive you sett it all the way up to 125 minutes, hope this helps!
Jun 13, 2007 | SanDisk Sansa e250 MP3 Player
Device keeps shutting off by itself and won't synch
Make sure the songs are in the right format. Napster is a real bear about disappearing songs - try another music svc.
Oct 11, 2006 | SanDisk Sansa e270 MP3 Player
I lost all my songs and now i cant put them back on
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Sep 23, 2006 | iRiver H10 MP3 Player
iLO (2 GB) MP3 Player Logo
24 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
