I tried to start the bike and the battery was low. I used a 55 amp quick charger to get the bike started, but it was running rough and stalled out. I then put the charger on it at 10 amps over night. The next day, when I turned on the key, there was nothing, no headlight, Nothing. I then tried to put the charger back on the battery and it would not even take a charge, it would not even indicate on the charger it was taking a charge. I checked the charger out and it was working. Is there a fuse that blew or is the battery that shot, it won't take a charge ??? The battery is 3 years old. Another question.....I don't have the owners manual, so where would I find the fuses or fuse box to check to see if a fuse is bad ??? Thanks for your help.......
At 55 amps you could charge the batteries on the space shuttle. A 2 amp charger is plenty. You cooked the three year old battery so a new one will be needed. Get the new battery then worry about the fuses only if the bike is still dead. The fuses are under the battery side cover if I recall correctly. Look under the seat if not by the battery.
Please rate this solution as a " FixYa ". Thanks!
SOURCE: problem with shaft drive (cardan) for my Yamaha Dragstar
SKU: 5FB-Y4617-00-00
SHAFT DRIVE SUB ASSY
Hi i just checked on stadium yamaha site and above is the SKU # for both, 98 and 03.... both the same so go for it
http://www.stadiumyamaha.com/pages/parts/viewbybrand/parts.aspx
SOURCE: how to lower the idle on a 2002 yamaha 650 v-star classic?
under the left side of the gas tank you will see i black knob/screw at the end of what looks like a hose. the knob faces the rear of bike. that adjusts the idle. its real easy to find and the only adjustment you can make to the carbs.
SOURCE: Need to get oil
First of all, I want to compliment you on your bike! That V-Star is in so many ways, one of the best all around bikes....Very durable engines, user friendly, comfortable and DEPENDABLE, not to mention one the best value to dollar ratio on the market, right along next to the Suzuki Boulevard....Not to get off subject but I enjoy these bikes thoroughly!
You want to make SURE that the only oil you use is a quality oil, which will have THE seal of approval stamp on the bottle that says that it meets the requirements of all the major motor corporations you want to make ABSOLUTELY sure that the ONLY oil that goes in that bike's crank case and gear box is specifically intended for use with a "MULTI-PLATE WET CLUTCH" system.....Otherwise a very bad day can be predicted. "Champion Oil" is a reputable brand and preferred thier 2-stroke raceing oil over all else when I raced 250cc class arena-cross. I have since retired from dirt bike racing to take up a much safer and peaceful profession in law enforcement....But I know Champion makes 4-stroke case oil thats compatible with wet clutches....Yama-Lube is ok too...Just make sure you see "Wet Clutch" on the bottle and it's all a matter of consistenly works best for you and preference after that.
SOURCE: uneven front tire wear
Idoubt your fork fluid levels have anything to do with uneven tyre wear,depending on where you live dictates how your tyre wears,if you live in uk then you tend to turn right more than left therefore wearing the tyre more on the right and reverse this for anywhere they drive on the wrong side of the road.tyre pressures are important... to check the fork fluid level you need to drain the oil into a measuring jug,compare result to manufacturers recommendation.if you are not mechanically competent do not attemt this as you may get hurt as the fork internals are under load from a spring
SOURCE: 02 Yamaha xvs 650 dragstar classic that misfires when it warms up
First I would change all the spark plugs, and if that didn't make a difference then it sounds like the coil(s) are warming up and breaking down........when it starts to skip take a good pair of pliers with good rubber on them and pull each spark plug wire, when you get to the one that the running doesn't change then I would replace that particular coil
look under the seat for the fuses
