Question about Compaq AMD Sempron160GB Desktop PC Bundle with CRT Monitor and Speakers (CPQSR1711NXBEL428A)
CD-ROM Drive Randomly Flies Open??
Okay, I am a computer geek myself, I'm pretty tech savvy so what ever information you give me I will probably understand it. The thing is, I have a Compaq Sempron that gets to be quite a pain sometimes. Anyways, some nights I'll be sitting on the internet or something, and then VSSSHHHH!! I'll look down and the CD-ROM drive will be open at random. It's really creepy, but it does it a lot. I don't mind that it comes open as much as the fact that it won't close easily. I can push it shut...and then I'll hear this idiotic, grinding/squealing noise, and then it will shoot back open again. It does this sometimes when its opened voluntarily by me as well (won't shut). Any suggestions? I thought that it might be an I/O conflict or something. Any help would be appreciated :) Thanks
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 11, 2008
Posted on May 06, 2008
A good registry scanner can clean up a lot of problems with your computer. Here's a link to a good free one:
Posted on May 04, 2008
    President:
  • 2,961 Answers
It's a sign that your cdrom itself is failing, it normally happens on boot up, when the drive will automatically open by itself. It is the drive/firmware; as the drive no longer responds correctly to open or cl;ose commands.
Posted on Aug 21, 2007
Except_handler4_common msvcrt.dll xp download
Option (1)
To resolve this issue, use the Windows XP Recovery Console to replace the Msvcrt.dll file with the original version. To do this, follow these steps:
  1. Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
    NOTE: Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
  2. At the Welcome to Setup screen, press R to start the Recovery Console.
  3. Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
  4. Type the Administrator password, and then press ENTER.
  5. With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
    • cd system32
    • ren msvcrt.dll msvcrt.old
    • CD-ROM_or_DVD-ROM_Drive_Letter:
    • cd \i386
    • expand msvcrt.dl_ BootDriveLetter:\windows\system32
    • exit
    NOTE: BootDriveLetter refers to the drive letter of the boot drive. In other words, it refers to the drive where the Windows folder is located, which is probably drive C. CD-ROM_or_DVD-ROM_Drive_Letter refers to the drive letter of the CD-ROM or the drive letter of the DVD-ROM drive. The CD-ROM drive or the DVD-ROM drive are frequently located in drive D.
Option (2)
Fix the registry issue with ADV Tweaks Suite Free.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Dec 02, 2013 | Microsoft Windows XP Professional
I have some floppy disks with pictures on them from as far back as 1998. When I put them into my computers A:/ drive i get a message that says -- A;/ not accessable No ID address mark was found on floppy...
If your not computer savvy like the address might be holding you up or go into bios to see if it is being reconized(floppy drive) you can take them to a computer tech shop and they will transfer them for you
Feb 17, 2011 | Dell Dimension 4400 PC Desktop
Cannot copy files, pictures ,or anything onto CD ROM. Tried different brand of blank CD (Maxell CD-R) and still cannot transfer any files. My other computer with the same drive will not recongnize the...
If a problem on 2 x pc's then its probably a drive issue.
Does it play CD/DVD's ?. If not you could try a CD lens cleaning disk, it may just need a good clean out.
As you're moving it between PC's then the IDE cable is probably connected properly.
My only other thought is that it is faulty, probably not worth repairing, you can get dual layer DVD/CD rw drives for under £15 on ebay.
Jan 02, 2011 | LG (GCC-4240N) CD-RW/DVD-ROM (Combo)...
My notebook is displaying there is a ile or corupt and to starting windows using a cd-rom or select r at start up screen but because there is no cd conpartment i can not do that and i have pressed r...
You are going to need an external CD-Rom to fix that problem, there is no way around it. Some people have used their original os CD from asus to make a Thumb drive solution that emulates a CD, but you first need a CD to do this. Try shopping at Geeks.com for the external drive, or try using a spare cd or dvd rom with their external cable kit.
I use a cable like this for my external CD or Hard drive hookups.
http://www.geeks.com/details.asp?invtid=2020-OTB&cat=CDR
Mar 14, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi, I have two cd drives that originally came with the Dell dimensions 3000 PC home edition I own, I've had them for a while, but recently my cd drive has ceased to work, the computer doesnt acknowledge...
The best bet and I have had several customers bring systems in with this problem is you have to edit the registry file and get rid of the upper and lower registry values once you do this save and reboot the machine it is just like a new drive was installed worked on all of theres one however came back to me twice and it turned out it was a conflict with other installed hardware. Hope this helps If you simply go to google.com and type clear upper lower registry values and the name and model of you drive as above it usually gives you a step by step and happy computing. Check us out on the web @ http://www.davispcrepair.com or contact me personally @ kzthomas@davispcrepair.com
Jan 14, 2010 | Dell Dimension 3000 PC Desktop
How do I get a cd rom to download to my computer from my GR-D290 camcord
Remove the CD disc from the camcorder and put in the CD drive on the computer. A windows may open automatically to show you the conmtents of the CD.
If it does not open automatically:
1. Use Windows explorer ... open "My Computer"
2. The CD will probably be listed as Drive D:"
3. Double-click (open) the Drive and each folder that appears on the drive.
4. The viseos will be listed...
5. you can copy (or "drag") these to a folder or your desktop.
Please reply with a comment if you need more information about this...
Sep 09, 2009 | JVC GR-D290 Mini DV Digital Camcorder
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
How to open a Sony Vaio PCVA-SB1 Subwoofer
call an assistance or technician to help you open your Sony Vaio
Jun 18, 2009 | Sony 182556522 1-825-565-22 SUB WOOFER...
CD ROM not working
OUR CD ROM WONT OPEN ON HP
Jun 10, 2008 | HP Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Compaq AMD Sempron160GB Desktop PC Bundle with CRT Monitor and Speakers (CPQSR1711NXBEL428A) Logo
206 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
