Question about Brother MFC 420CN All-In-One InkJet Printer
Faxing I try to send a fax by punching in the fax number, then placing the documents face down on the top bed, then sending it through, but it keeps telling me that the line is busy, is my fax hooked up to my Vonage and DSL and pc correctly?
  • 78 Answers
Do you have the phone cable connected to the LINE socket and NOT the EXT socket on the side of the printer? M
Posted on Aug 21, 2007
SOURCE:
I am trying to send a fax on my parents fax machine but do not know which way to insert the paper. It is a brother MFC-7860DW
  • if you are going to fax from the glass or scanner bed you should put your document face down on the glass
  • if you are going to fax from the feeder (on the top of the machine) then you should load your document face up in the feeder
How to send a fax?
  • when you want to send a fax ,press the FAX key to illuminate it in blue
  • put the document either in the feeder or on the glass
  • enter the fax number using the dial pad
  • press START
Jul 29, 2011 | Brother Office Equipment & Supplies
I am trying to fax on the 6170 do the sheets face up or down?
If you are sending fax using the scanner bed, your original document should be placed face down. However, if you are sending faxes using the automatic document feeder, original document should face up.
Jun 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
When faxing paper should the face be up or down
If you are using the Automatic Document Feeder (ADF) for faxing, place your original document face up. If you are using the scanner bed, place your original document face down.
For more information, you refer to the Lexmark Pro705 User's Guide. If you are using Windows, you can access it by going to the Start menu -> Programs -> Lexmark -> Pro700 Series -> View User's Guide.
To download the user's guide for free, click on this link Lexmark Pro700 Series User's Guide.
I hope this information has been helpful. Thanks.
Jan 17, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
How do I fax a sheet of paper?
First step is to connect the phone line to Line 1 Ext at the back of the printer port.
Place the document face down on the Scanner Bed Or place the document face up on the Top feeder if you want to use it.
Use the right arrow key and choose Fax Black and press OK
Dial the # you want to send Fax to and Press OK.
The fax should be sent.
Regards,
Ron
Dec 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
I need to know how to send a fax from a brother MFC-295cn all-in-one printer
Hello Frank,
Sending a fax is fairly simple.
1. Make sure you have a telephone line connecting to the LINE jack on the side of the MFC-295CN
2. Check if you have a dial tone by pressing the "hook" button on the machine while the line is free.
3. Place a page face down on the flatbed scanner or in the document feeder on the top of the machine.
*Note: If you are using the document feeder, once the page is placed in, you should see "enter fax #" on the LCD
4. Enter the fax number the same way you would dial a regular phone number.
5. Press "Start"
*Note: If you are using the flatbed option, after the sheet is scanned, you will be asked if you want to scan a second page. For additionnal pages, press 1, to end scanning and start faxing, press 2
6. If the fax goes through properly you will see "completed" on the LCD
Mar 25, 2010 | Office Equipment & Supplies
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Dec 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Faxing
If you are using the Auto-feeder, it needs to be face up. If you are placing the document on the glass, then it needs to be face down.
Jun 25, 2008 | Brother MFC-7820N Laser Printer
Faxing multiple pages
If it's only one page.. just place it on the glass face down.
When faxing muliple pages you must place them in the automatic document feeder located on top of the machine.
Place all originals print side up (up to 35 pages). A message will show up in the display letting you know original were loaded up properly. Let me know it this helps.
Apr 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
107 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
