Question about Philips MCM298/37 Shelf System
Plug hi i live in uk ,i used one plug from 2 blades to 3 blades,when i pluged it ,it worked for a 2 seconds then it turned off ,then i cant switch it on again...plz help
That's because it is over heating since there is a difference of voltage
Posted on Feb 19, 2008
SOURCE:
Husqvarna mower a few seconds after engaging blades the stop working turning off and then turning back on th ed blades work again for a few second and the quit work in g again
What model Husq?
Does it have a electric/ magnetic head drive ? If so it probably has a bad or faulty wire to the drive clutch assembly.
Oct 19, 2014 | Garden
I have bought a second hand iphone 4s and it is locked to the 3 sweden network but i live in the UK can i unlock it to use it on UK network, I have taken the phone back to factory settings and cant ge
The phone needs to be network unlocked from apple server to use it with any sim card worldwide. You need to pay for this either at local shop or online webstore.
I recommend: http://www.guaranteedunlock.com/iPhone_Unlocking
Mar 23, 2013 | Apple iPhone 4S
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
I have installed a garden outhouse which has come with a 3kw heater in the roof and has a 3 wire cable hanging from it. I have an RCD external socket to which I've connected a 10m re-enforced 3 wire...
The switch is probably a single pole switch and just switches the incoming live to the output, in your case the live from the RCD to the outgoing live of the heater. The 2 earths can be connected together and 2 neutrals. When you mention the RCD external socket I presume the cable to the outhouse is fitted with a three pin UK plug so check the rating of the I66 switch to ensure it can cope with the 13 amp current which can flow.
A double pole switch would be preferable. This provides total isolation and switches off the incoming live and neutral of the cable from the RCD. This is safer because if anyone ever rewired the plug at the RCD and mistakenly reversed live and neutral, a correctly wired single pole switch in the outhouse wouldn't switch off the live and this would be a hazardous situation, especially since the heater is in an outhouse which could be damp.
Jul 22, 2011 | Garden
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
I have a panasonic breadmaker SD 207 and Icannot
I think the best place to try is Ebay.UK I found this one there...maybe it will fit. Seems they all look alike. Good Luck, Hank
http://cgi.ebay.com/PANASONIC-BREAD-MAKER-PAN-KNEADING-BLADE-SD206-SD200_W0QQitemZ310127333030QQcmdZViewItemQQptZUK_HGKitchen_SmallApp_RL?hash=item4835078ea6
Jan 28, 2010 | Panasonic Kitchen Appliances - Others
All the lights are flashing and it says to Reset power. I disconnect the power cord and reconnect. The system looks like it is resetting and then the same flashing lights appear and it again says to Reset...
Hi Joe,
Lets try 2 steps:
1st approach:
1. With the printer “ON” unplug the power cord form the printer.
2. With the printer now unplugged, press and hold “# and 6′ keys in the printer..
3. While still holding these keys down, plug the power cord back.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
2nd approach:
1. Unplug the power cord
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
(repeat 3 times)
If none of these to approaches work, I’m afraid the failure is “fatal” as the main circuit board might be fried L
Regards,
Ed
Nov 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Ps3 turns on then off
does it go yellow than blinks red if it does either 1.is experinceing vennelation problems wich I cant help you with or 2.the ps3s hd is fried in wich you are ****ed sory
Sep 30, 2009 | Sony Playstation 3 (PS3) Console
Hi i bought my technics 1210mk5's in america and when i gor back to ireland i had them converted to 220v as this particular model is not dual voltage. The 1210's worked fine then when i used a plug pin...
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Jul 10, 2009 | Technics SL-1210MK5 Turntable
My Kenwood SB300 Smothie maker blade won't whizz around
Hi. Go to http://www.kenwood.co.uk/Customer-Service/ and hopefully that will get you headed in the right direction!
Mar 10, 2009 | Blenders
Philips MCM298/37 Shelf System Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
