Question about NEC MobilePro 900c Pocket PC
Mobilepro 900c Ethernet Card
Hi I am trying to see if I can get my 900c use a PCMCIA ethernet card. I see Chris's website that gives a list of Cards compatible with Windows CE . Below is the link http://www.pocketpcfaq.com/peripherals/pccardethernet.htm But...he mentions something of the sort that many can only be used with Windows CE 2.0 and some are hardware specific and won't work on other H/W. Does anyone know PCMCIA Ethernet cards that will work with 900C esp the 3com ones.
  • 3 Answers
See http://www.hpcfactor.com/support/
Handheld PC Hardware Compatibility List http://www.hpcfactor.com/hcl/hpchcl.asp
Click on wired cards on drop down Search the HCL: form and leave the other part blank.This will give you all you need to know ;)
Posted on Nov 03, 2007
I use the AVAYA wireless card. It needs to be wireless B. Dowload the driver for it when you sync. Then it should work.
Posted on Aug 22, 2007
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
PCMCIA
A PCMCIA Netword adapter/card will fit into this slot. This adapter is used for wired or Ethernet connection of the laptop to the network.
Hope this helps!
Nov 10, 2008 | Computers & Internet
Nec Mobilepro 900c
right clik my computer,go to properties,click on properties,click on hardware devices you will see the list of all the hardware components installed on your computer,check to see if your network adapter is installed,if not installed you will see a yellow balloon attached to the adapter icon,then try and install the device.if the device is installedbut you can't browse,i think that has to do with you internet configuration.try using the a unique computer name and the correct workgroup name,good luck.
Feb 27, 2007 | NEC MobilePro 900c Pocket PC
32-bit card bus PCMCIA
No. The MobilePro 900 PCMCIA slot only supports 16-bit PCMCIA (PC Card) cards.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Memory/Storage
Additional storage can be added to the MobilePro 900 by adding memory cards to either the CF Card slot or the PCMCIA (PC Card) slot. There are several types of memory cards available, including Flash Memory and miniature hard drives, in both the CF and PCMCIA form factor.
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Open Questions:
I WAS TRYING TO INSTALL JLIME ON MY MOBILEPRO 900, EVERYTHING WAS DONE AS PER THE DOCUMENTATION AS PER THE WEBSITE. AFTER ALL THE STRESS OF PARITIONING THE FLASH CARD.. I GOT THE FOLLOWING ERROR.. "ROOT=/DEV/HDA2" NOT found kernel Panic VFS cannot mount I dont understand a bit of this error.. i ahve tried all the zImage files on the website.. but still I am getting the same error. I used the Henchman.tar--------( All the versions avaliable on website" Haret.exe as kernel Bootloader file which read as below # boot a kernel with HaRET # # have the kernel zImage and the Haret executable in the same dir as this file # this file if named 'startup.txt' will automatically launch the kernel when you start Haret # # 'set MTYPE 659' is for the NEC MobilePro900c # # in CMDLINE change 'root=' to point to the location of your root filesystem # eg 'root=/dev/hda1' is the first partition on your CF card # and 'root=/dev/hda2' is the second partition # set KERNEL zImage-2.6.23mp900c set MTYPE 659 set CMDLINE "console=tty0 console=ttyS0,115200n8 root=/dev/hda2" bootlinux i have tried mentioning "hda1" , "sda1","sdb1","sdb2" I believe its not the problem with the Henchman file or is it??? I have the following partitions sdb1 as boot flag which is fat-1GB sdb2 which is of ext2-2GB sdb3 as SWAP-1GB i loaded the boot files in the Fat ie the Haret.exe Zimage and startup.txt file in fat system Please help me out in removing this error and getting Jlime installed in My Nec Mobilepro 900.. I used a transend 4GB flash drive
Jul 16, 2011 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c Pocket PC Logo
164 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
