Question about Olympus Camedia C-4000 Zoom Digital Camera
Lens motor Motor is working and tries to move lens but lens won't extend. Seems like the gearing has disconnected.
  • ergognome Aug 21, 2007
    Thanks. I guess there is no way of stripping it down to get to the gearing is there? I had an on-line quote of $199 plus shipping, still cheaper than a new one!
    Thanks, I assumed that was so. Appreciate your feedback.
    Genius:
  • 2,985 Answers
You are nearly right or even has stripped gears. Check out Olympus for a possible repair I do not think you will be jumping for joy at the price though.
Posted on Aug 21, 2007
  • john ash
    john ash Aug 21, 2007
    Send it in - You need special tools and of course access to parts.
SOURCE:
Canon Sx1IS lens error Hi My Canon Sx1 is is
sounds like the motor is cactus to me, have you checked to see if there is any drive (power) to the motor?
Sep 06, 2013 | Canon PowerShot SX1 IS Digital Camera
I have a Canon IXUS970IS and the lens is stuck 3/4 out. I do not know how it happened as I loaned the camera out and it came back like this. I am told it just happened. There is no evidence that the...
I will say with 95% certainty the camera was dropped while the lens was extended. It does not take much of an impact to make the Canon lenses lock up, a very small drop, or even banging the lens into a door or something while it is extended will do this. It happened to my Canon, and two other friends' Canon cameras as well! Googling the issue also shows how common this is. I had my camera hanging around my neck and merely bumped my extended lens while opening a door. The gears inside are SO fine, and it skips just one tooth and it will fail. It sucks.
Sending the camera in to Canon for repair seems to be the only option, since you already tried gently push/pull/twist of the lens while it tries to retract. That worked for one friend, I sent mine into Canon for $50 repair.
Sorry.
Sep 08, 2011 | Canon PowerShot SD890 IS / IXUS 970 IS...
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
LENS OPENING BUT NOT SHUTTING
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
My Kodak Easy Share camera turns on. then off immediately without the lens attempting to extend. It seems as if it's really trying, but won't go on. Replaced with a new battery. Still nothing. ...
Your previous diagnostic definitely indicates a mechanical problem, once the possibility that a false sensor signal to the main board as the cause by resetting all functions. It is very likely that there is a blockage or a broken internal part that is preventing the correct positioning of the lens which triggers the shutdown and error display.
You can try some of the procedures listed below to fix it yourself. These simple steps have helped many people restore their cameras to functionality.
Before trying any of the suggestions, make sure your Camera has new or fully charged batteries and it is in recording mode. Try compressed air. With a fine tip can of dry compressed air (not a blow dryer) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It could possibly remove all dust and sand. Turn the camera on and it should function fine.
The links below give additional step by step DIY instructions on troubleshooting and attempting to fix this problem. A Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser. Pay special attention to the opening statement at the first link if there is any chance of warranty repair.
Check this links for additional details that could find in this article link: fixing-lens-error-on-digital-camera.html
Additionally, here is a video of the normal power up sequence of the camera and there other moethods:
1. Here is the first alternate method
2. Here is the second alternate method
Hope helps.
Jun 08, 2011 | Kodak EASYSHARE V1253 Digital Camera
Camera was laid on its face and now lens won't open. worked fine before
This is a situation where the lens has jammed in it housing, there is a motor that extends and retracts the lens. One of two tings have happened, the motor has seized, or the gears have jammed preventing the lens from moving. This will require a camera technician to see if it's possible to repair lens in the housing.
Jan 15, 2011 | Kodak EasyShare C613 Digital Camera
Lens barrell doesn't retract for zooming out, only for shutting off.
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Oct 29, 2007 | Kodak EasyShare DX6490 Digital Camera
Lens on Casio EX-S100 Won't Zoom
(EX-S100) You need a new lens assembly. I know this from experiece because I have the same camera and it tried to extend while in its case as well. I found that there are plastic gears that extend this lens assembly and that they are basically destroyed when the lens assembly is not allowed to extend on power-up. I have searched for a replacement part with little success. I found one repair shop that would ship me the part for more than the original cost of the camera. Good Luck!
Sep 03, 2006 | Casio Exilim Card EX-S100 Digital Camera
Olympus Camedia C-4000 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
