This usually means that there is a program open that is unable to close itself properly, or maybe you have a document that has not been saved, so there is a dialog box asking if you want to save it, but you cannot see if it since you are on the shutdown screen. When it asks if you want to force shutdown, you should see a list of which programs are still shutting down, check on those.
If you are using the Remote Desktop Connection option of Windows, then the only option it provides is to logout. If however, you can get to the Command Prompt (Admin), then you can use the 'shutdown' command from the command prompt window. Type in 'shutdown /?' to see a list of options.
Simply formatting the hard drive does not remove all residual traces of the previous installation. When you get to the step for formatting, go to the advanced button and delete the partition that contained windows 8. Then create a new partition in the space, format, and install windows 7.
Hi Good day!!if you are using windows go to command prompt. press windows logo key + r to display run dialog. type cmd and click ok. in the command prompt type the following commands and press enter: shutdown.exe -s -f -t 0 -s = shutdown -f = force shutdown closing all programs -t = time in millisecond 0 = now you can change this no. to schedule your shutdown.
for ubuntu open terminal and type -sudo shutdown 0 you can change the 0 if you want. Hope my solution help you!!
next time your computer starts go to a command prompt and type chkdsk/f it will ask you if you want to run chkdsk next time your computer starts ..say yes..and then restart the /f command repairs damaged sectors..that might help..
You will be prompted to enter a serial number while installing the Nero
9 Trial version. Copy your personal Trial Serial Number and paste it
into the prompted dialog box during the installation of Nero 9.
Try this "Trial Serial Number": 8M01-20CX-4294-TL10-U4U0-UKE2-MMT7-AHWX
Guideline: How to enter the Trial Serial Number
1. Double-click the Nero 9_trial.exe file to start the installation. 2. During the installation you will be asked to enter a new serial number. 3. Copy the serial number above and paste it into the requested field in the Nero installation dialog box. 4. Click the "Add" button. The installation will continue.
1.Call from a touchtone phone. 2.During greeting message, enter your remote code. (Code is "11" by default, or you can set your own beforehand via Menu>Initial setting>Set answering>Remote code>enter your desired 2 digit number) 3. Unit will announce number of new messages, and play them back. 4.After 3 seconds, voice guidance will start; follow as necessary.
Bypass voice prompt by pressing: 1 Repeat message (during playback) 2 Skip message (during playback) 4 Play new messages 5 Play all messages 9 Stop (to resume, enter a command w/in 15 sec, or voice prompt resumes) 0 Turn answering system off *4 Erase this message (during playback) *5 Erase all messages If answering system is off, you can force it back on by calling and letting phone ring 15 times. Good luck. Hope this helps!
