Question about Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 580EX Fault
At switch-on the flash head vibrates back and forth as if the gun is searching for its zoom position. This lasts for about 5 seconds then the zoom indicator on the LED starts to flash.
  • sTcA Nov 04, 2007
    Same problem (after falling on the floor from a chair)
    Problem Solver:
  • 9 Answers
Same problem after a 30 cm falling on the floor. U must open the head of the flash and rearange the flash Bulb on the moving(zooming) track. images of how to u cand find HERE
Posted on Nov 18, 2007
    New Friend:
  • 7 Answers
Yep as mentioned it sounds like the zoom head mechanism is jammed, follow the instructions here
Posted on Jan 20, 2013
580 ex zoom does not work properly and make a noise
When you manually zoom does it make the sound, or on the camera? One thing to try is change out the batteries, maybe there is not enough juice to work as needed. If doing that does not help, then I would contact Canon; the flash may need repair.
1 (800) 652-2666
Hours:
Monday-Friday 8:00 a.m. - 12:00 midnight. EST,
Saturday 10:00 a.m. - 8:00 p.m., excluding holidays
For additional support options: www.canontechsupport.com
Cordially,
Oct 04, 2014 | Canon SPEEDLITE 580EX TTL Flash
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
Zoom flashing
This will come on if you manually activated it on the back of the flash. It's for the times when you want to manually provide wide or tele coverage.
Jan 17, 2014 | Canon SPEEDLITE 580EX TTL Flash
SPEEDLITE 580EX TTL Flash: flash is making a constant beating/clicking noise ...
Loosen the two small screws under the flash on the swivel head. Turn flash on. You may need to twist the head just slightly. Flash bulb moves back and forth in the swivel head when zooming. If you dropped the flash, this may have jarred it from the track. I had the same problem with mine, and the above solution fixed it. Zoom works again and no clicking noise. Let me know.
May 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
Wrong owner's manual here for Canon Speedlite 580EX Flash
You can get the proper manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=14998
Dec 27, 2009 | Canon SPEEDLITE 580EX TTL Flash
I have a Canon Speedlite 580EX, the flash will not go off.
Perhaps the unit is set to master/slave mode. Look into that.
hint: Press and hold on the zoom button to get into the master/slave menu
Dec 04, 2008 | Canon Speedlite 580EX II TTL Flash
Frozen on one setting
Try this site and follow the photos.
It worked for me.
327093-how-repair-canon-speedlite-580-ex-dupa-ce-vibreaza-capul.html
May 26, 2008 | Canon SPEEDLITE 580EX TTL Flash
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
317 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
