Question about Fuji FinePix E510 Digital Camera
Flash The flash is not working anymore. Green light shows up, but no flash is coming. Bulb looks OK, wires not damaged or anything. Camera has not fallen or exposed to shock.
  • Anonymous Nov 27, 2007
    Yea the same thing happens to me...The camera works fine and everything...never dropped or any damage done to it...but the flashh doesn't flash when the flash is taken out
    Genius:
  • 2,985 Answers
Try taking a flash picture- by pressing the shutter release whilst you are holding the camera to your ear. You should hear a high pitched whine as the capacitor charges up. If you cannot then the flash unit is bust- thats all one can say really -it is not usually a user fixable thing - not that is ,you have appropriate skills, and the parts are available. Check out FUJI for part availability and/or repair costs.
Posted on Aug 23, 2007
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
Green indicator light on dash no longer flashes
It is possible that you have broken the filaments in both turn indicator light bulbs. So, check the bulbs first. If they're ok, check for power getting to the bulb sockets - and make sure the ground wires are still attached.
Nov 18, 2009 | 2005 Honda VT 125 Shadow
No Picture
Need to change ur picture bulbs or tries to refits the bulbs.
Sep 24, 2009 | Panasonic PT-44LCX65 Television
When switched on, indicator light shows green then to red flashing then red continuously - unable to press shutter button or show menu
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Sep 04, 2009 | Agfa Easy Pix SP2 Digital Camera
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
My camera won't turn on
Hey GClooney,
Most cameras come with a 1 year manufacturers warranty so the first camera is most likely covered by this and I would have it looked at by an authorized service technician. If you dropped you Polaroid a300 camera then there is most likely internal damage and that should also be addressed by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but the first camera repair would most likely be covered by its warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 17, 2008 | Polaroid a300 Digital Camera
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Fuji FinePix E510 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
