Question about JVC KD-G420 CD Player
Doesn't keep memory
Have had my stereo installed but i have to constantly set the stations etc after i have turned the car on and off. The schematics that i have are in russian and indonesian and can't make out what wires to fix myself
  • 26 Answers
DIKA, first step - check your stereo batt backup wire , you must connect that direct or continues voltage from accu. Don't switch this wire, you can check if your car in off position , this  wire must still have voltage +12v - +14v if no voltage check your fuse near batt backup wire. Why that wire must have voltage,that's because the voltage used for backup your stereo memori. OK good Try , Fixya and Don't forget to vote me, thank's
Posted on Nov 03, 2008
I had the same prob with a kenwood all i had to do was swap the ignition cable with the battery cable ie:default is red(ignition)cable from unit to red cable from car and yellow(battery)cable from unit to yellow cable from car all i did was swap them over ie red from unit to yellow from car and yellow from unit to red from car it keeps its settings now!!!
Posted on Aug 21, 2007
SOURCE:
Was fiddling with car stereo, accidently touched black and yellow wire, think I've blown something cos now neither stereo or central locking works! Please help.
Black is ground, yellow is battery constant power for memory (clock, station memory, etc...) you burnt the fuse for that constant battery power. Just check for burnt fuses
Mar 22, 2015 | Cars & Trucks
STEREO ETC STAYS ON EVEN AFTER TURNING IT OFF AND REMOVING THE KEY
It sounds like you have a constant 12V power supply wired to the radio instead of a switched 12V. If you've recently installed a new radio, check your wires again. There should be a 12V constant and a 12V switched. The switched 12V will turn the radio off, while the constant 12V is for keeping the clock and radio memory working.
Nov 07, 2014 | Honda Cars & Trucks
Volkswagen beetle elecrical problems
most of the constant power for the wires are use for the memory system of ur stereo eg. for the clock memory, am/fm preset station memory (custom setting of the user). even when u turn off the key, the stereo will not reset to it's default settings.
Jun 04, 2013 | Cars & Trucks
HAVE TO SET RADIO STATION EVERY TIME UNIT IS SWITCHED OFF HOW TO SET PERMANENTALY . ALSO WANTED TO KNOW IF DISPLAY COLER CAN BE CHANGED
For Pioneer car stereos to keep the station memory the wiring is as follows:
Yellow is 12v constant
Red is on with ignition switch.
Orange/white is for lighting switch.
as for display color, need to know the head unit model.
Dec 30, 2010 | Pioneer Car Audio & Video
I hook up a jvc kd-s16 and it will not keep the memory of the stations can you help
The yellow wire is the constant 12+V.
It has to be hooked up to a constant battery source.
If you did not install an aftermarket wiring harness consult
http://www.installdr.com/QuickWiring.html to find the constant 12+V wire color code in your dash.
If you unhook your battery, you can splice into the cigarette lighter hot wire to keep the constant memory of stations and clock time.
Aug 01, 2010 | JVC AM FM CD DET FACE CAR STEREO
Stereo does not store adjusted audio settings and restarts after being turned off
Check to make sure the yellow from the stereo harness is connected to constant battery, connected to the battery, when the ignition switch is off, the yellow wire still has power. The yellow wire is for the memory for the stereo settings and radio station presets.
May 16, 2010 | Car Audio & Video
Stereo stations wont stay set
If you have a yellow wire that is the memery wire. It needs to be hooked to a constant hot. If you do not have one you need to get a new plug for the back.
Feb 24, 2009 | Kicker CVR12 Car Subwoofer
Memory of presets
You need to Check the Wiring Harness from the Stereo. There is a Constant Power Memory Wire (Should be Yellow or Orange). This needs to be Connected to the Cigarette Lighter Power Wire for Constant Power Memory. Please Rate My Response! Thanks!
Feb 07, 2009 | Pioneer DEH-P6400 CD Player
When my daughter turns her car audio off, we loose preset stations.
Two questions to narrow this down - one, is it an aftermarket stereo, or a factory one? Two, with the key out of the car, can the stereo be turned on?
If it's aftermarket and it powers on when the key is off, then it's likely two wires are reversed in the harness behind the deck - the constant 12v wire and the switched 12v wire. The constant one is the yellow one, which always supplies power to the deck, keeping power there for the preset memory and the tone settings. The ignition-switched one is so that when the key is turned off, the stereo shuts off (this is the red wire on the harness). If these were reversed, the stereo would always be able to be turned on, and power to the memory settings would be lost when the key is turned off.
Sep 10, 2008 | Car Audio & Video
JVC KD-G420 CD Player Logo
281 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
