Question about Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive
My DVD Rom is not detected by the system
My samsung DVD rom is not detected by the system moreover it shows the icon of the DVD rom in the My Computer but never reads it or writes on it. Moreover if i give a command to eject it never ejects the Rom i have also replaced the IDE cable and power cable but nothing worked.
  • 1 more comment
  • lilig Jun 30, 2008
    MY COMPUTER IS NOT DETECTING MY DVD OR CD DRIVES LIKE THEY ARE NOT INSTALED
  • krishna17049 Sep 14, 2008
  • Anonymous May 12, 2009
    Samsung Combo drive is not detected although there is power supply in the drive
My samsung combo drive is not detected by the system
Posted on Mar 09, 2008
  • 983 Answers
I have samsung conbo rom which was working fine... after some days some dvd s were not were after little more days dvds were only not working... after some cds were also not working.. but it was detect by system it was showing every disc as blank...
after some days it s not detecting by system but it s detecting in bios.. i reinstalled os xp sp2 also but also no improvements.. i only just opened and made it to detect in os but now also it s not detecting anything it s not writing also..
suggest the solution pls.. i only like to repair it as i m an engineering student...
mail me @ :[email protected]
Posted on Feb 05, 2008
    Scholar:
  • 53 Answers
When it comes to installing a new driver you have to make sure is supported by your PC, that said it may be that you need an installation CD, if the driver does not come whit one try to download it from the website of the manufacturer. another solution can be that your driver may be conflicting with another driver, this means that your problem driver needs to be a master or slave check on the installation manual that came with the driver. Try this
Posted on Aug 25, 2007
SOURCE:
When I enter the DVD in the ROM it show nothing.When I click the DVD ROM icon It shows no disk in the ROM
It might be a bad lense sensor of the DVD ROM or you can also try putting in other DVD/CD disk, if it still doesn't detect them then I suggest you replace the DVD drive.
Apr 16, 2011 | Computers & Internet
Samsung DVD Rom Drive does not read disks
Usually when you buy a DVD ROM drive it comes with software. However, I bought a LG one and it didn't come with any software. All I can tell you is to update the system BIOS and the firmware that came with the drive. Look on the top part of the drive when you take it out of the system.
Go to the manufacturer's website and download updated firmware for the unit.
Aug 04, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
I cant play a disc or DVD
Please try to reboot your laptop then go to CMOS Settings and detect the CD/DVD Rom and try to see if it is detected by your system. If it is detect ted then exit CMOS Settings and then load the Operating system you have and ope the DVD/CD Rom you have. But if it does not detect the DVD/CD Rom then i advice you to find a computer technician to help you fix the problem cause hardware problem is the main reason why it does not detect the disk drive you have, its either the connection bus is not properly plug or the Disk drive is damage or not functioning well.
Thanks
Aug 04, 2009 | IBM ThinkPad T30 2366 Notebook
Display Dvd Rom
Hello my friend, please try to reboot your computer then goto CMOS and check if the DVD Rom that you have is detected by your system. If it does not detect then you can manually detect a device using CMOS function. Also try to check if the connectivity of your DVD Rom is not diabled otherwise enable it to detect your device. If all the above steps you followed then the result is still the same then please find a computer technician in your place then let him open and fix the problem.
If you need more assistance my friend please reply to this post.
Thank you.
Jul 28, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
My Samsung DVD RW Drive icon Has changed in to DVD RAM Drive Icon in the My computer, today!!! The problem is that i cannot open any sort of CD's, DVD's Pls!! M in big trouble!! i removed da drivers in the...
is it sata dvd rom or ide dvd rom?
at first remove the dvd rom. check it is primary or secondary slave selected it. then add the dvd rom.
go to the bios options. check the dvd rom position.
selected is secondary dvd rom. check the power cable.
icon can change it does not mater. you need to open the dvd rom.
Jan 29, 2009 | Computers & Internet
Icon showing without installing a dvdrom
what operating system and spesc thanks
Jul 24, 2008 | Computers & Internet
Dvd-rom icon missing
(1) Check bios for detection if detected continue the following steps else DVD is gone or you can remove test it in other system.
(2) You can manually DVD from control panel by clicking add new hardware wizard, continue the step.
(3) last option try install your operating system agin.
Apr 19, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Cdrom not detecting
attach another drive to your system boot your system with bootable windows cd and make your system drive c
install windows in c drive
this problem is incounter
when u install the window in other drive than c
Dec 22, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Logo
1,360 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
