Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
KDF-60XS955 Optical Block is Bad.....
Can anyone tell me where I can get a good price on an optical block for my TV since sony will not do anything. Thanks for any advise I can get.
We complained to Sony so much about the optical block thing and they actually replaced for free. The cost roughly $1000.00 to repair and that's why we complained to Sony because we had not had our tv maybe 3 years and when you spend that kind of money on a tv like that you expect it to work and not replace things after 3 years. Write Sony and keep at them.
Posted on Apr 18, 2009
  • 58 Answers
Probably too expensive to repair.
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Posted on Mar 24, 2009
SOURCE:
In the bottom left corner of our tv there is many blue dots we need to know how to fix that and how much would it cost to fix it
Bad Light Engine/optical unit block Assy PN# A-1084-668-A
Price $1,828.79 Core refund $1,060 Finally cost of part $768.79 Encompass Parts Distribution 1-800-638-3328
PTS rebuilts light engines 1-800-844-7871
UED 1-800-648-6657
Oct 27, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Has a blue ring around the outter edges of the screen
Hey there it sounds like your LCD chips are burning out and the problem will just get worst if you don't replace the OPTICAL BLOCK is your TV under warranty check this out Sony got a lawsuit for there bad OPTICAL BLOCKS
http://www0.epinions.com/msg/show_~threads/cat_id_~13/id_~9877/forum_id_~127
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 08, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
How do you manually set the convergence on a Sony KDF-60XS955
lcd projection sets don't need a flash focus ...there is no convergence alignment. replacing the optical block should be all you need to do. the block contains the lcd panels with the picture already aligned.
Jul 09, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue tint at the bottom of the screen
Your optical block (light engine) is going bad. A very expensive part. Sony has a history of trouble with a lot of these. Sont will also sometimes warranty them for customers. Contact them with your model, serial, and date of purchase. Good luck.
May 31, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Projection TV - glowing blue in corner of screen
That sound like the optical Block or otherwise known as the light engine
This still may be covered by sony's warranty
I would call them and see it is a very expensive part
Feb 08, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Oct 29, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
1,478 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
