Question about Welbilt MR670TB Microwave Oven
Touchpad the touchpad in my "welbilt microwave oven, model 6500T (220V)" does not function. Some buttons - only with numbers, ex. 7, 8, 9, 0, - do (clicking sound is heard) but yhe oven cannot start. I have never spread any cleanser neither over the pad or inside and generally always have much care when using it and handling. I used it for many years (10). Can it be used up?
  • popabeck Aug 26, 2008
    Only some of the buttons on the Hotpoint microwave oven RVM143wk01 work. Could be a bad keypad or touchpad. How much does it cost to replace keypad?
  • 661 Answers
Sounds like your keypad is worn out, if you are able, this is most likely to be a modular part and could be replaced, (if you can find a replacement) the buttons are made of a thin deformed conductive sheet which makes contact when pressed to a flat layer underneath (seperated by an insulative layer) this flexable condictive layer becomes brittle with use and over time the edges of the flexable zones split. once that happens the button doesn't work you should be able to get a replacment keypad tho, or canabalise a dead one for the replacement keypad have fun :)
Posted on Aug 24, 2007
SOURCE:
Not all buttons work on touchpad
There will be a problem with the touchpad membrane, usually this is usually repaired by replacing the complete touchpad facia or front control panel.
Nov 10, 2013 | Goldstar MV-1515 Microwave Oven
Power cuts off when starting oven or micro
see the diagram attached and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jul 08, 2013 | Whirlpool RMC275PD Microwave Oven
Microwave pcb
Possible causes:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
see the diagram attached, and fix it. Gd bless youbef996d9-693d-4cfe-90fb-e21e76b39fef.jpg91f4ce2b-15bd-4144-9f14-be817d4574ef.gif
May 28, 2013 | Microwave Ovens
I search for the instruction to a microwave Welbilt MR 6500T... help pls!
Find Welbilt Breadmaker manuals here:
http://manualfox.com/link/welbilt.htm
Oct 25, 2009 | Welbilt MR95TW Microwave Oven
The touchpad is not functioning
Found part number to be A630Y5940AP try http://www4.ued.net/catalog/cat_item_idx_2099.html or search part number
Aug 03, 2009 | Microwave Ovens
Need roller guide for Welbilt microwave model MR626T w/turntable - can u help?
Welbilt was sold to Haier Corp. So maybe this works:
Contacting Welbilt Phone (Haier): (877) 337-3639
Mail:
Haier America
1356 Broadway
New York, NY 10018
USA
Nov 17, 2008 | Welbilt MR626T Microwave Oven
Need manual
The part numbers were MW-9999-04 OR IB-MR95TW but they are shown to be no longer available.
However, one dealer lists it as being available here.
Good luck.
Oct 15, 2008 | Welbilt MR95TW Microwave Oven
MR 522W Welbilt microwave oven
While, the original part number was MW-4000-08, to my knowledge, parts are generally no longer available for Welbilt microwaves. The good news is that this knob should be for a standard 1/4" shaft with a flat side, and appliance parts stores, home centers, and home improvement stores will have a good selection of knobs. If you take your old one, you should be able to get help matching it so it will function for you. Good luck.
May 14, 2007 | Welbilt MR95TW Microwave Oven
While the original part number was MW-4000-08, to my knowledge, parts are generally no longer available for Welbilt microwaves. The good news is that this knob should be for a standard 1/4" shaft with a flat side, and appliance parts stores, home centers, and home improvement stores will have a good selection of knobs. If you take your old one, you should be able to get help matching it so it will function for you. Good luck.
Microwave Ovens Logo
101 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
