Question about Creative Labs Zen Touch MP3 Player
REALLY SPOILED!!!! My creative Zen Touch could not be turned off, volume could not be pressed.Also, i could not turn on the zen touch.However, i need to charge the battery fully and when i plucked off the cable, then,the screen will be turned on. I brought this only this year.Should i changed into a new mp3 or get this repaired?PLS HELP!!!!
    Problem Solver:
  • 55 Answers
Sounds like a bad motherboard to me. However, it may just need a firmware update. Have you tried to update the firmware yet? If not, go to www.Creative.com -->Support -->Downloads -->Follow the correct language and country links -->Select the correct options for Zen Touch -->Select Firmware Download the firmware and try to upload it to your Zen Touch. If your Zen Touch is not recognized by the computer, its best to buy another MP3 player, as your motherboard is bad.
Posted on Sep 06, 2007
My mp3 player stays on all the time and i cant turn it off
  1. Check that the Creative Zen Touch has the most current version of the firmware driver. Firmware updates typically fix most common errors and problems encountered when using the Zen Touch. Turn on the MP3 player and select "System" in the home menu. Click "Information" then press "Settings." Select "About." Look for the internal firmware's version number listed under "Version." The most recent firmware is 2.01.00 and was released in 2006. If your software is outdated, download an update from the Creative support site: http://support.creative.com/downloads/download.aspx?nDownloadId=100120
  2. Ensure that the song files you are trying to transfer to the Zen Touch are compatible with the player. On your computer, right click the song file to view its file format. The Zen Touch can play all unprotected WMAs, WAVs and MP3s. It does not support the popular protected AAC format that is used in online stores such as Apple iTunes.
  3. Verify that the Zen Touch's internal battery is fully charged. This may cause what appears to be a blank or dead screen, as well as slow responsiveness to your touch. Insert the power adapter brick connector into the Zen Touch's power port found on its right-hand top corner. Plug the adapter into a wall outlet to begin charging. The MP3 player will be finished charging in four hours. You may use the MP3 player while it is charging, but this may slow down the charging process.
  4. Adjust the screen contrast on the Zen Touch. This may resolve any issues you have with viewing the screen in bad lighting. From the main menu, click "Settings" and choose "Contrast." Slide your finger up or down the Zen Touch's touch pad to adjust the contrast to a suitable setting.
Sep 24, 2009 | Creative Labs Zen Touch MP3 Player
Upgrading Creative Zen?
Go to the Creative support site and upgrade the old MP3 player. The new Player will sync with mediaplayer and you can install music.
Feb 01, 2009 | Creative Labs Zen Touch MP3 Player
Creative zen touch and Apple Mac computer
Your was Creative brought with its own software, wasn't it? Well, this software isn't compatible with Mac. However, you can use a free app so you can still use your creative. http://www.wentnet.com/projects/xnjb/
Jan 24, 2009 | Creative Labs Zen Touch MP3 Player
Zen wont turn on or charge
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Sep 21, 2008 | Creative Labs Zen Digital Media Player
Creative Zen Touch stuck in "recovery mode"
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Jun 30, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen Touch
I cant recommend this but.....
from what ive been reading people have been smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I
Dec 08, 2007 | Creative Labs Zen Touch MP3 Player
Creative zen
· Download recovery tool off creative's website.
http://us.creative.com/support/downloads/
Sep 30, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen Touch MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
