Question about Toshiba Stratagy 4 Lite Voicemail System Phone
Call will not Transfer to Voice Mail
All incoming calls will not transfer to voice mail. I have the default ring set to 4 and additionally, I have my greeting set up. Any thoughts on why calls will not transfer to vm?
  • 2 more comments
  • krhoa Aug 22, 2007
    Thank you for responding. I finally figured it out. All I needed to do was program my telephone. I found a book hidden away on a shelf that gave me the codes. My phone now transfers to vm if I do not answer or am on the phone.
  • dimarshall Aug 06, 2008
    I have a similar problem with an older Stratagy DK system. When I reset the base unit for voice mail retrieval nothing is changed. I've tried deleting the extension from the Stratagy system and re-establishing it but still no luck. Is there a specific code sequence (undocumented?) that will work?
    Thanks,
    dave
  • Anonymous Mar 13, 2014
    I work at the senior center..we have several phones..calls do not go to voice mail...phone just keeps on ringing. All the phones at the center are affected. How do we fix this?
  • Anonymous Mar 26, 2014
    why can I not transfer a call when the next line is ringing but I have open lines
    Novelist:
  • 201 Answers
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Posted on Aug 21, 2007
SOURCE:
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
How do I access the voice mail on my LG Neon 2 cell phone?
  • Press and hold the "1" key to call into your AT&T voice mail.
  • 2
    Enter the default passcode (your seven-digit telephone number--not including the area code) using your keypad.
  • 3
    Press "4" to access the "Personal Options" menu. Press "2" to enter the "Administrative" menu, and then press "1" to change your passcode. Enter the default passcode, and then enter your desired passcode. Listen to the playback for verification.
  • 4
    Wait until you are returned to the main menu. Press "4" for "Personal Options," and then press "3" to change your greeting.
  • 5
    Press "1" to change your "No Answer/Busy" greeting, or press "2" to change your "Extended Absence" greeting. Follow the voice prompts to record your personal greeting (this replaces the standard "answering machine" recording).
  • Read more: How Do I Set Up My LG Shine Voice Mail? ' eHow.com http://www.ehow.com/how_5984327_do-lg-shine-voice-mail_.html#ixzz15IGt4VZz
    Nov 14, 2010 | Cell Phones
    I have 1 extension that will not go to voice mail. I have tried the *713 and a 2 digit number between 00 and 99 and it still just rings endlessly. When I make an inner office call to this ext... it picks...
    What happens when you TRANSFER an outside call to that extension? If that works, you have Intercept issues which is handled with programming. If it still does not transfer, you have CF issues, started by a *710x command for both internal and outside calls.
    Carl
    Aug 11, 2010 | Panasonic KX-T7633 Corded Phone
    How do I send a call to internal voice mail?
    Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
    Jun 29, 2010 | NorStar M7324 Telephone
    We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
    Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
    Apr 16, 2010 | Cell Phones
    Toggling between greeting 1 and greeting 2
    Hi, what do you want to change? What feature is programmed on the button?
    "EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
    **CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
    **SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
    (CICS AND ICS 2.0+)
    **ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
    **BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
    **SET NORSTAR SET PROFILE
    **LINE NORSTAR LINE PROFILE
    **USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
    **TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
    *0 BUTTON INQUIRY
    *1 FEATURE KEY EXTERNAL AUTODIAL
    *2 FEATURE KEY INTERNAL AUTODIAL
    *3 FEATURE KEY PROGRAMMING
    *4 PERSONNEL SPEED DIAL
    *501 SELECT ENGLISH
    *502 SELECT FRENCH
    *503 SELECT SPANISH
    *6 RING TYPE
    *7 DISPLAY CONTRAST ADJUST
    *80 RING VOLUME ADJUST
    *81 MOVE LINE KEYS
    *82 DIAL MODES
    *831 AA ON/OFF (CICS)
    *832 CCR ON/OFF (CICS)
    *833 AA/CCR RECORDING MAINTENANCE (CICS)
    *84 AUTO LOG OPTIONS
    *85 CALL LOG PASSWORD
    *89 PROGRAMMED RELEASE
    *9 RUN/STOP
    0 SYSTEM SPEED DIAL
    1 SEND MESSAGE
    #1 SEND MESSAGE CANCEL
    2 RING AGAIN
    #2 RING AGAIN CANCEL
    3 CONFERENCE / TRANSFER
    #3 CONFERENCE SPLIT
    4 CALL FORWARD
    #4 CALL FORWARD CANCEL
    5 LAST NUMBER REDIAL
    60 PAGE GENERAL
    61X PAGE INTERNAL ZONE (1-6)
    62 PAGE EXTERNAL
    63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
    64 LINE POOLS
    65 MESSAGE REPLY
    #65 MESSAGE REPLY CANCEL
    66 VOICE CALL
    67 SAVED NUMBER
    68 RESTRICTION /COS OVERRIDE
    69 PRIORITY CALL
    70 CALL TRANSFER (BLIND)
    71 LINK (HOOK FLASH)
    72 TIMED RELEASE
    74 CALL PARK
    75 GROUP CALL PICKUP
    76 DIRECTED CALL PICKUP
    77 CALL DURATION TIMER
    78 PAUSE
    79 EXCLUSIVE HOLD
    800 TRUNK ANSWER
    801 CALL QUEUING
    802 GROUP LISTENING
    803 SHOW TIME
    804 WAIT FOR DIAL TONE
    805 TEST SETS (2.0)
    806 HIDE DISPLAY
    808 LONG TONES
    810 MAKE BUSY
    811 CALL INFORMATION
    812 ENTER CALL LOG
    813 LOG IT
    815 AUTO BUMPING
    817 IRAD TRANSFER (CICS ONLY)
    819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
    #819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
    82 CAMP ON
    83 PRIVACY CONTROL
    84 LINE REDIRECTON
    #84 CANCEL LINE REDIRECTION
    85 DO NOT DISTURB
    #85 CANCEL DO NOT DISTURB
    86 BACK GROUND MUSIC
    #86 CANCEL BACKGROUND MUSIC
    87 "SERVICE MODES (DR-3,4,5)"
    #87 CANCEL SERVICE MODES
    870 SHOW SERVICE MODES (CICS)
    871 EXTENDED RINGING (ICS)
    #871 CANCEL EXTENDED RINGING
    872 ALTERNATIVE RESTRICTIONS
    #872 CANCEL ALTERNATIVE RESTRICTIONS
    873 ALTERNATIVE ROUTING
    #873 CANCEL ALTERNATIVE ROUTING
    88 VOICE CALL DENY
    #88 CANCEL VOICE CALL DENY
    FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
    "VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
    THE FOLLOWING ARE SOME COMMON USAGES:
    9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
    9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
    9*1 CHECK FEATURE CODES FOR VOICE MAIL
    9*2 SMDR Admin
    9*3 LOGGER TIME STAMP
    9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
    9*4 NORSTAR DOOR PHONE PROGRAMMING
    9*5 FLASH LOW RANGE CHECK FEATURE CODES
    9*7 ACD ADMIN MAINTENANCE SESSION
    9*9 VOICE MAIL INTERFACE (VMI) CODES
    900 SMDR,enter an account number to be logged with the call
    901 ACD LOGIN
    901 VMI Admin
    902 ACD UNAVAILABLE
    903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
    903 ACD CANCEL WRAP
    904 ACD HELP
    904 FLASH ACD LOW RANGE LOGIN/OUT
    905 ACD CATEGORIZE
    905 FLASH LOW RANGE DN IDENTIFIER
    906 ACD RECORD CALL
    906 FLASH LOW RANGE VM TRANSFER
    907 FLASH LOW RANGE VM INTERRUPT
    908 STAR TEXT (OBSOLETE)
    908 FLASH ACD LOW RANGE BUSY MODE
    909 ACD ANN. MAINTENANCE
    909 FLASH ACD LOW RANGE QUEUE STATUS
    910 FLASH LOW RANGE LEAVE MESSAGE
    911 FLASH LOW RANGE OPEN MAILBOX
    912 FLASH LOW RANGE OPERATOR CONTROL
    913 ACD CALLS QUEUED
    913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
    915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
    920 ACD ADMIN SESSION
    921 ACD ROUTING SESSION DAY/NIGHT
    922 ACD ADMIN STATISTICS SESSION
    923 ACD GROUP STATISTICS SESSION
    960 DIAL BY NAME (CINTECH NSVM OPTION)
    961 DIAL BY NAME ADMIN (PSWD=1234)
    980 VM SEND MSG TO ANOTHER MAILBOX
    981 VM LOG INT MAILBOX
    982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
    983 VM ADMIN PROGRAMMING (PSWD=1020000)
    983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
    984 VM TIME AND DATE(STARTALK Pswd=1020000)
    984 AUTO FOREWARD TO VMAIL(NSVM4.0)
    984 FLASH ACD LOGIN/OUT
    985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
    986 VOICE MAIL TRANSFER
    987 VOICE MAIL INTERRUPT
    988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
    988 FLASH ACD BUSY MODE
    989 RECORD CALL (NSVM 4.0)
    989 FLASH ACD QUEUE STATUS
    Mar 11, 2010 | NorStar M7310 Corded Phone
    Trying to program a touch for incoming calls that will go through my voice mail directly
    This can be handled by the DND feature in your admin settings... Do not disturb will transfer your calls direct to voicemail without ringing the handset.
    May 18, 2009 | Mitel 5212 IP Phone
    Need more rings
    You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
    Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
    Fax pick up
    Greetings Nana,
    I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
    If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
    When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
    1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
    Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
    Ron Baird the friendly Kodak guy
    Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Night switching for KX-T7630
    You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
    You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
    Carl
    Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
    Lands Phones Logo
    1,645 people viewed this question
    Top Toshiba Lands Phones Experts
    martin hogg
    Marvin
    Marvin
    Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
