Question about HP OfficeJet 7410 All-In-One InkJet Printer
Paper feeding. I have a HP Officejet 7410, as well as a Photosmart 8150, both of which frequently pick up more than one piece of paper and feed them through at different rates, the result being that half a page is printed on on piece and half a page on the following. I've tried using thicker paper to no avail..... any tips?
  • 1 more comment
  • kkmaisey Aug 21, 2007
    thankyouthankyou....will give it a go, however they both do the same thing with paper that has already been used on one side - so has some air between. I'm hoping that the right side copy tip will work though. Cheers!
  • Anonymous Mar 24, 2014
    TRIED REINSTALLING SOFTWARE. DID NOT WORK.
    REINSTALLING SOFTWARE DIDN'T WORK.
    Genius:
  • 2,985 Answers
Careful 'knocking up' and 'riffling' the sheets before placing in the feed tray will go a long way to to alleviate this one. Getting air between the sheets is the object of the exercise . The cutting packing and wrapping of sheets compresses them. Did you know also that there is a right side and wrong side to copy paper? Look at the side or end of a new pack for the arrow.
Posted on Aug 21, 2007
The paper will not feed through when printing
clrean the rollers
using the printer maintenance , its built in under services
use the correct setting for the paper type '
check for small pieces of paper or objects caught in the paper path
tip it upside down see if anything falls out
Aug 19, 2012 | HP OfficeJet 7410 All-In-One InkJet...
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
My HP 2575 Photosmart all-in- one will not feed paper. Message says out of paper when it is full of paper
there is paper feed sensor inside the printer. make sure it is there and not broken off. the sensor is in the back center of the paper tray, and is spring loaded. if you can't find it, shake the printer with the paper tray facing down to see if a black piece of plastic falls out. the printer will also have this error when the printer cannot pick up the paper. clean the rubber roller with "rubber renew". you can use rubbing alcohol but rubber renew is recommended. the roller is often full of dust and fine paper debris.
Nov 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
False paper jams and multi sheet feeds
multi feeds and jams are mostly caused by static electricity in the paper. ALWAYS fan paper top and bottom to remove static and "aerate" the paper before putting in prnter. Doing that will reduce the problems you are experiencing.
Please rate my help++++Thanks for using FIXYA
Oct 22, 2009 | HP Photosmart 8150 InkJet Printer
Officejet Pro L7780 will not feed paper from bottom bin. Tries twice then defaults to top bin
Check that the paper path is clear.
Check that the paper is dry.
Check that the paper pick ups and rollers are clear of any debris - Power off the machine at the mains and brush them with a damp cloth or brush and maybe vacuum out the entire area to remove all dust etc.
Make sure that you fan out the paper before inserting it into the tray and that the tray is not over full as this will prevent the paper being collected successfully. Try running with half a tray full instead of a full or near empty tray.
This should resolve your problem.
Sep 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My printer does pick up any paper
This video will help with that problem.
May 07, 2009 | HP Officejet J4680 InkJet Printer
Feeds to many pieces of paper into feed Officejet G85
Hey Bob,
Sounds like the pick up rollers and seperation pad could be the cause of this. They might need to be replaced
Feb 11, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Will not "Print" copies.
It may be that you are putting the page face down in the paper feeder when it needs to be face up or the other way around.
Jan 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Paper Feeds in Crooked
The paper size in the feeder and the paper size in your printing properties have to match.
I.e. if your printing format says "letter size" and in your feeder is legal or A4 paper you will get this error.
Please reply if this does not help.
Dec 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Paper tray won't feed paper & I get a false paper Jam code
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Oct 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
106 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
