Question about Nokia 6111 Cellular Phone
Can this be fixed
I finally got the covers but in the process i snapped in half the paper that joins both the front face and the back. i assume its what makes the screen work. if anyone has any idea what im talking about or can even let me know if this "thing" is replaceable. cheers from oz.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
If you are talking of the flexible conductor as paper then Yes, this is a replaceable part though it is usually soldered to a phone part in one side (the screen in your case) and have a plug or connector in the other side so you may need the complette screen replacement if the screen conductor is cutted.
If your phone is a slider or flip model and that was the bus between both movible parts then there would be a connector in each board (usually though not sure, may vary) and you can try to find the replacement in any shop.
Good Luck...
Posted on Oct 20, 2007
How do i clean the rollers on my printer?
Paper Tray Rollers Step 1 Turn off and unplug your HP printer. Pull out your printer's paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
Step 2
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
Step 3
Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Internal Pickup Roller - Laser Printers Only Step 1 Turn off and unplug your HP printer. Open your printer's front door and pull the printer's toner cartridge toward you to remove it from the printer.
Step 2
Locate your printer's internal pickup roller. The roller is gray or black, and it is made of rubber. Lift the roller upward, towards the front of your printer. Pull the roller gently out of the printer and lay it on a clean surface, such as a desk or workbench.
Step 3
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the pickup roller with the cloth. Fold the cloth in half and repeat the cleaning process until the roller is free of dust and debris.
Step 4
Wipe the roller with a dry, lint-free cloth to remove any remaining dust or debris. Let the roller dry completely before snapping the pickup roller back into place inside of your HP printer. Reinstall the toner cartridge and close your printer's door.
Aug 10, 2014 | Dell 1720dn Laser Printer
Canon mg5250 continually says 'no paper' there is paper, no jams, just a clunking sound when it tries to print and fails and says 'no paper reload' yet again. How do i rectify his please?
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards. Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
Sep 27, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Error message: remove paper standard bin
If you look to the printer, on the way out there is a small flag that usually gets stuck and then you get the error "Remove Paper Standard Bin". Simply look at the image below to see which flag I am taking about. Make sure it didn't came out of it's holder and if it did, just fix it back in so that when you lift it up it falls down easily. In my experience this always fixed it.
http://tinypic.com?ref=30xfqrl" target="_blank"><a href=http://i52.tinypic.com/30xfqrl.jpg" border="0" alt="Image and video hosting by TinyPic">
Jan 27, 2011 | IBM Infoprint 1332 Laser Printer
My Dell 1700 prints half the sheet, then stops
I have the same problem. Open the back cover of the printer and in the centre of the rollers to feed the paper out there is a paper sensor (a lever assembly attached to a switch) that lets the printer know when the paper has 'arrived' at that point in the printing process and also when it 'leaves' that part of the printer. On my printer the top of the lever has somehow snapped off so the lever/switch isn't being activated when the paper arrives at that point and the printer assumes there is a jam somewhere. I have removed the lever and glued a small piece of plastic to it to replace the piece that's broken off. It's a fiddly repair and I've had to re-do it a couple of times. I need to find a replacement assembly but part seem to be hard to come by and I don't know the part number to do an internet search.
Jun 23, 2009 | Dell 1700n Laser Printer
Document jam
I had this totally annoying problem this morning. After looking for any obvious paper jams or small bits of loose paper, I tried several fixes: 1) open front cover, release levers that hold white rollbar in place, roll the bar forward to make sure nothing is stuck behind it, snap levers back in place; DID NOT fix the problem; 2) open top cover, remove print cartridge, look for jammed paper bits, close cover; DID NOT fix the problem; 3) unplug the machine, wait a few minutes, turn machine back on; DID NOT fix the problem. I even unplugged the machine, opened ALL the covers, turned the machine upside down and shake it to see if any paper clips, staples, or other objects have fallen inside the machine; DID NOT fix the problem. FINALLY, I pulled the paper feed tray forward, reached down to the feed rollers, twisted them a few turns, put paper back in the machine, and the "paper jam" message disappeared! This may not work for everyone, but it worked for me today, so I hope this helps someone out there to have a better day.
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Aug 29, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Samsung ML-2510 printer paper jam
This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
Aug 03, 2008 | Samsung ML-2510 Laser Printer
Samsung sgh-j700 - cant remove battery cover
I found the same problem when I bought my J700. Shoddy design. If you wear rubber gloves the back can be slid off in the direction of the arrow.
Aug 02, 2008 | Cell Phones
Watch cover
1)put a little silicon grease around the case cover 2)put cover back on the case 3)lay the watch on a hard surface spicifically on the edge of a wooden chair or bench and the face of the watch on your palm, the case cover is under and paded on the chair or bench. 4) now gently press the watch and it will snap.
Mar 17, 2008 | Watches
Mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Jan 03, 2008 | Brother MFC-7220 All-In-One Laser Printer
Nokia 6111 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
