Fujitsu Siemens AMILO Pro V2000  PC Notebook
Problem for Fujitsu Siemens AMILO Pro V2000 (FAP:GBR-148100-P01) PC...
Wireless LAN switch not working - can it be set any other way
By brian502 on Aug 21, 2007
The wireless on/off switch does not result in the wireless light coming on. Is it possible to turn on the wireless through control panel or similar?
Same Problem
Jul 17, 2008
-   same issue...no wireless connections found and light is no longer on when I push the wireless button. Enabling network adapter in network settings does not work (in fact my wireless adapter is not being detected at all) -   dfourmet
Jun 16, 2008
-   my light is staying orange not wirless connections-   buddybees4
Apr 16, 2008
-   wireless switch not working . lights dont turn on-   sistronia
Mar 16, 2008
-   ca't turn wireless lan switch on-   Guest
Feb 01, 2008
-   My problem is similar, I have an acer aspire and it's switch does make the light come on, and a thing on the screen say 'Wireless LAN enabled' but then nothing happens. I've reinstalled drivers and been everywhere tring to find a solution.... Help!
PS: If you have that 'Acer empowering technology' green button on your screen, the power settings in there will turn my WiFi light on.-   Haroldo
Best Solution
posted on Oct 17, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #1 by Benimur WORKS!
Thanks dude.
Solution #2
posted on Aug 28, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the same thing actually happened to me when i accidentally hit the switch and couldn't turn it back on. as a desperate attempt at anything except taking the laptop apart, i took out the battery after i shut down the laptop and put it back in. the wireless was back on after i turned on the laptop.
Solution #3
posted on Aug 21, 2007
Somewhat Helpful)
Benimur
Rank: Guru
Rating: 88%, 3830 votes
Unfortunately no, most laptops uses a miniPCI WiFi Card with a switch that is hardwired to one of its pins. That pin must receive a signal (or absence thereof) to activate.
Control Panel activation is actually the enable/disable feature, but it's still got to be mechanically switch on, otherwise it will still not function even if enabled (which I suspect you already have tried).
Although there might be a way to trick the wifi into thinking it was mechanically switch on, however it is no longer swtichable to off (meaning always on). First, you must determine if your laptop uses a miniPCI WiFi Card similar to the image shown below left. If yes, you have to cover pin # 7 as illustrated below mid image. You would need Scotch tape about 1.0mm wide and 4.0mm long to cover the pin.
Of course the usual precaution applies, AC power off, battery removed, possible void of warranty, can possibly make your unit inoperable (unlikely though still possible) and others as may be applicable.
Good luck and hope this works for you. Post again how things turn up or should you need further information. Kind regards.
Comments:
Aug 21, 2007
- Hi again,
some would venture that it is actually pin # 13 (i.e. count include the other side). Cheers.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
Somewhat Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5982 votes
you can go to control panel>network connections, right click on your wireless network adapter icon, and select enable.
Was this helpful?
Yes
No
Solution #5
posted on Sep 23, 2009
Not Rated)
kc2ujh
Rank: Apprentice
Rating: 0%, 0 votes
that scotch tape fix works great.
Was this helpful?
Yes
No
Solution #6
posted on Sep 15, 2009
Not Rated)
msbenson
Rank: Apprentice
Rating: 0%, 0 votes
Beimur's fix worked perfectly. Takes some time to get the tape just right but now my wireless works!
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens AMILO Pro
Questions and Unsolved Problems for Fujitsu Siemens AMILO Pro
Do you recommend Fujitsu Siemens AMILO Pro V2000 (FAP:GBR-148100-P01) PC Notebook?
Answer
Answer
I have fujitsu siemens v2000 model fb2i. Suddenly the screen doesnt come on at all. It switches on,... (More)
Answer
My computer can't find my amilo cam. not in picasa or facebook or anything. the blue light is of.
Answer
how do i fix an ultrasound machine that does not display images on the display tube?
Answer
I cannot go wireless with my broadband and I cannot download flash. please help. Yvonne Mulcahy
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 07, 2007
says i need to turn on the wireless switch, i see a switch on the side but if you try to turn off it always goes back to the on direction and there is no light that says its on
Comment by Guest, posted on Dec 06, 2007
An X is displayed in the icon at My Network Connection, Unable to connect to the internet, Bluetooth not working.
Comment by not again, posted on Nov 04, 2007
i have a hi grade laptop orange broadband and belkin wireless adapter connected 4 das ago but wont now
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , PA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
