Question about Sony CDX-M8800 CD Player
Programing stations hi how do i prigram n save stations on my system?are the two cables labelled SUB meant for connection to the woofer?can this system support cd changer? how do i do the connection?
  • 69 Answers
I have included a step by step to store your stations. The cables are meant for a sub and yes your system does support a sony cd changer. To install a changer you have to pull the deck and there is a outlet on the back.
Posted on Aug 26, 2007
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
Oct 24, 2014 | Panasonic Televison & Video
Can i hook up my bose model ps38 powered sub to onkyo reciever
Why not. A speaker system should work with anything that produced sound meant for a speaker.
Don't you think?
find the woofer out on the onkyo and connect the bose sub-woofer there.
Seems pretty simple. If you don't think so, go hide in a closet.
NOW!
Aug 19, 2014 | Audio Players & Recorders
Subwoofer noisy when powerd on.
Speaker wires are backwards,
faulty audio or optical cable,
system or cable tv is not grounded
Apr 14, 2014 | Audio Players & Recorders
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
I am attempting to reconnect my home stereo but do not see a cord or wire to connect the bass to the system. is there supposed to be a connective cord for the bass speaker? it is a 530 watt MHCGX99 model...
Hi from one Lakers fan to another 8^) - Yes you do. You need a cable to plug into the
sub-woofer out port on the receiver to the connection on your sub-woofer.
If you can't find the original cable, get a short (three ft.) standard stereo cable (one that has two cables, a white and red). Just plug one of the cables (the red or the white but it has to be the same color on both connections) into the receiver and the sub-woofer.
You'll be ready to pump up the bass.
Enjoy and thank you for using Fix Ya
Mikeywaf
Mar 12, 2011 | Audio Players & Recorders
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Sony CDX-M8800 CD Player Logo
90 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
