Question about Toshiba Satellite M45-S351 Notebook
Screen display has gotten smaller.
Ive been using this unit for about a year and have had no problems up until now. My display for some reason suddenly got smaller. I can still see the entire window, but there is a portion about 2 inches wide on the right and half an inch on the bottom of the screen that suddenly no longer displays anything, almost as though the computer doesnt know that its there. Along the right side the screen is black, and the bottom there are many lines of different colors. The computer is still working fine except for this problem. Does anyone have any suggestions to get the full screen working again?
  • 1 more comment
  • marystar Aug 28, 2007
    After doing some of the trouble shooting tips, nothing happened. Then, for apparently no reason, after about a day of not using the computer the whole screen started working. but its blurry, like it is stretched. I fooled around with the video options, but nothing worked. Do you know what could have caused any of this, or how to make the screen clear again?
  • marystar Aug 31, 2007
    OK, now the screen went back to only being about 3/4 a screen. Does this seem like there is a bad connection between the computer and the screen? Is there a physical problem with the screen? Sorry about the situation changes, but my computer seems pretty random about this right now.
    Thanks, I thought that this may be whats wrong for a while, but right now my screen is clear as can be, its just that the window is only taking up about 2/3 the screen. There is a portion of the screen at the bottom and right side that doesnt work, but the entire wondow is squeezed into the area that does work, and perfectly focused, so there isnt any part of the window that i cant see.
    A couple days ago, the full screen started to work again, but it was out of focus(This was one of the posts). And then afer a couple days it went back to the squashed but clear screen(Last post). Im not sure whats causing these changes, It seems like the computer is capable of displaying a full clear screen, just not at the same time.
    Any advice would greatly be appreciated.
    Sergeant:
  • 279 Answers
Should you need any help replacing this, this site has instructions on replacing the LCD, as well as how to figure out which version of the LCD your laptop uses. Apparently Toshiba used more than one version in their M45-S351 http://www.tdcomponents.com/TOSHIBA-notebook-displays/TOSHIBA-Satellite-M45-S351-notebook-display-2910.php They also sell the displays, but I didn't see how good their prices were, since I didn't know which one you needed.
Posted on Aug 31, 2007
  • Toshiba Master
  • 12,061 Answers
Well this is unusual & interesting.. (sic)I can still see the entire window(sic) I wonder if somehow the Display Drivers have gotten Screwed up.. Try un-installing your graphics hardware Drivers,then re-install the latest Drivers for your system. Of course B4 ya do any of that try adjusting your windows display to any other resolution and see if this changes things.. Below is a helpful link... www.microsoft.com/enable/training/windowsxp/appearance.aspx
Posted on Aug 21, 2007
  • electronic & computer repair&  servicre
    Ok that comment about it being "Blurry" thats wat game me the Clue... what is happening is the Horizontal Output section is going faulty... this is where a number of voltages are produced also the "Focus" mechanism.. on the Horizontal Output transformer there is a control that one can adjust to "Focus" the CRT .. the fact that ya had that last problem and now with the "Focus" I am fairly sure thats whats wrong.. Hmmm time for a nice new LCD ?
HTC HD7 going blank on calls...
I had this same problem. There could be a few reasons. Starting with the simplest:
Finger placement; sometimes your fingers may wrap around and touch the screen while using it causing the proximity sensor to turn the display off.
Screen protectors; I got lucky because my problem was being caused by the screen protector i was using. It had come off a bit in my pocket and gotten scratched on the part that touches the screen which messed up with the proximity sensor. All i had to do was take off the protector and the problem was fixed.
Sensor Malfunction; The proximity sensor in the phone is malfunctioning and you can try to hard reset the phone but usually if it is malfunctioning you just need to get it fixed or replace the phone. If your phone is still under warranty you should probably use it.
Jun 10, 2012 | HTC HD Windows Phone 7
My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Hi, i brought my unit at 2008. During this 2 years i used my unit a lot and for that reason i have lost my serial number (scratch). Is there any option that i can update my unit with new maps of Canada...
If the serial number isn't present on the outer case then you can find it another way.
Turn on the machine and press and hold the battery icon until the screen goes into diagnostic mode. The data displayed on the 1st screen will include the serial number. CAUTION: don't fiddle with any settings unless you know exactly what you're doing, but there are a few useful items on some screens including the facility to set the headphone output to line output. It's really useful if you want to stream music from the machine into an audio head unit.
Please take a moment to rate my answer.
Jul 22, 2010 | Garmin nuvi 255W GPS Receiver
Ive got a Samsung U900, hardly had any problems up until now (Had it just over a year) The phone display keeps freezing and the screen keeps going blank, can anyone help please
this exact same problem happened to me 5 months ago, i had the fone replaced with insrance and again i have the exact same prob! obviosly a recurring prob
Nov 07, 2009 | Samsung U900 Soul Cellular Phone
On my laptop the screen picture has gotten smaller and the outside of it is black. i dont know what the problem is. it is an old laptop and i dont no whether its from age.
Its not actually a problem or a fault, its just a setting that has been changed in the video card settings.
There are two ways to fix it.
One of them is to adjust the resolution, right click on your desktop and select properties, from there select the last tab which says settings, see the resolution slider, slide it towards the higher end, where the numbers get bigger, and apply, if the problem got worse you have gone to the wrong direction, if the black area is smaller or gone you have gone to the right direction. adjust the resolution until you don't have black outside on the display.
if the text and icons become too small, you need to open the advanced settings from the page, and find monitor scaling settings so that the computer fills the whole screen regardless of the resolution in use.
After you have found the scaleing setting you can go back to the resolution slider and slide it down untill you can read the screen well, the picture should cover the whole screen.
Sep 06, 2009 | Compaq Evo N610C Notebook
Strange display screen issue
If you have had the camera for less than a year, it may still be under warranty. Call 800 730 6597
Nov 13, 2008 | GE E1030 Digital Camera
Shots are small, and water leaks from bottom of unit
You machine has an internal leak and this is why you shots were getting smaller and smaller. The more time goes by the more it leaks, hense, the reason for smaller shots.
You should have someone look at your machine.
Saeco Service Center for New York
www.cerinicoffee.com
Nov 21, 2007 | Gaggia Syncrony Espresso Machine
Sony Grand Wega 50" LCD
We ahve the same problem. If you find a solution please advise.
Sep 07, 2007 | Sony KDS-R50XBR1 50" HDTV
Rt2250 rt2500 speaker static noise hum buzz until fully warmed up
It sounds like a capacitor in the power supply is just about to die. With the power disconnected have a look at the large tin can looking gizmos near the power transformer. There could be a couple of them. Leave the unit switched off for a while before going near them they could still pack a splat. Replace them with the same value and make sure they're connected the right way and it should solve your problem. Whilst in there have a good look for any other smaller capacitors which look as if they're getting rounded at the top. Replace them too. Either that or dig deep and buy a new one.
Oct 23, 2005 | RCA RT2250 System
Toshiba Satellite M45-S351 Notebook Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
