Question about IBM G41 Monitor
Blue screen when i on my cellphone the color of the screen is blue but theres sound. sometimes line appeared & then blue screen appeared on my cellphone. please give me suggestion what is the problem and why is it happened? thnak you.
0 characters
1 Points
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computer Monitors
Lines in screen
They are stuck pixels...
There are some that say sending strong images that change from to color to color can help unstick them, but I say only dissassembly and cleaning of the contacts (there should be 2 ribbon cables, one for top, one for side) that probably got dust in it. Call it in under warranty if at all possible.
Apr 19, 2009 | Sony KDL-52XBR4 LCD Monitor
Monitor is blueish
If the Blueish problem appears try play around with the VGA cord and see if the Colors comes back, if not, try hiting the monitor to see if the lines and color problem comes bcak to normal. If not your monitor's circuit board needs some dry solder, it could be the cold solder problem. Cheers.
Jan 21, 2009 | LG Studioworks 700S 17" CRT Monitor
Inspiron 8500 laptop monitor; vertical lines & color bursts
It sounds to me like you are having a problem with the video card on the motherboard, I am not familiar with this model but some you can remove the video card and upgrade, some you can not.if you can upgrade you can try this
if you cannot remove the video card then a new motherboard will be required to fix this computer.
you can look on ebay for a replacement at a reasonable price or talk to your local computer service center.
hope this helps.
Jan 09, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Colored vertical lines
It is a tossup between a bad LCD panel and the logic board. The only way to tell for sure is to change out the logic board or have it tested on another unit. Checkout for instruction videos on that unit as well as parts.
Jun 19, 2008 | Dell 2000FP 20.1" LCD Monitor
A follow-up on my Dell vertical lines issues
I understand that it seems odd that sometimes they disappear.
I have a vertical line on one of my laptops right now that it takes about 3 seconds before it appears on the screen but once it's there. It's there.
I think it has to "warm up" before it comes back.
I used to do Technical support for a company that produced computers with 5inch wide screens, and everytime something with a line was mentioned, "Fix display cable" was the reason.
Because everytime you pushed the screen up to see the keyboard the line disappeared (because the display cable moved) But I digress.
All I'm certain of is that if you change the display cable this will be fixed.
Mar 15, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
This is caused by the driver tabs between the LCD panel and the controller board that runs it inside.
In general, it is not a repairable thing, and can be very expensive to repair if you choose to go that route.
Please note this is not the video card that is inside the monitor,(where your cable from the PC connects to the monitor) but the actual driver board for the panel.
Jan 14, 2008 | Dell E196FP 19" LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computer Monitors
Computer Monitors Logo
Top IBM Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you an IBM Computer Monitor Expert? Answer questions, earn points and help others
