Question about Pioneer VSX-D510 Receiver
Pioneer VSX D510 Reciever (power supply or the main amp circuit problem)
I have had this reciever for quite awhile now but i have never gotten it fixed. It turns on and then says a message of power off. I removed all the speakers and any other connections and the same message appears and it still says power off and shuts off. Is there any solution if it is a power supply or main amp circuit problem? Thanks!
  • 3 more comments
  • blackace33 Nov 09, 2008
    I'm having the same problem. Does anything have any solution?
  • Anonymous Jan 31, 2009
    i have the same problem and if you turn it on 3 or 4 times in a row it starts smoking.
  • Anonymous Feb 23, 2009
    I have the same problem
  • Anonymous Apr 05, 2009
    I have the same problem also. Has anyone tried calling Pioneer?
  • Anonymous May 20, 2009
    i think that it might be the internal amps
    New Friend:
I'm having the same problem. I read on a kind of VSX-D510 eletronic manual tha says POWER OFF "When displayed, it's the case where DC is in the output of AMP".
Do you know what does it means? How can I solve the problem?
Posted on Jan 30, 2011
SOURCE:
I have a Pioneer VSX-D510 reciever with 5 speakers and sub. The sub keeps making continual popping sounds at higher volume levels when watching movies, tv etc. Have to turn most of the way down. Also,...
Manuals help a lot.
Tell us about the speakers. Maybe they're not compatible.
As far as what to expect to hear from surrounds, that depends on the sound engineering.
Test tones for speaker setup will get it all dialed in. Page 17.
Mar 05, 2011 | Pioneer VSX-D510 Receiver
PIONEER VSX-27TX RECIEVER
Hi!
you can locate the R9371 & R9374 beside or the same circuit of the IC 9374 Very near not far to IC 9374.
Nov 22, 2007 | Pioneer VSX-27TX Receiver
I am trying to hook my playstation 3 up to the pioneer vsx 510 using a digital optic cable. I have everything set on the playstation but still cannot get any sound. I am not that familiar with the reciever...
Be sure youve selected the optical output option on your ps3 (in sound options on your XMB) ... now on the back on the amp under the optical input it says CD. Select CD input using the toggle know or your remote and then on the front of the amp press the button labeled"signal select"(in between DSP select
Jul 10, 2010 | Pioneer VSX-D510 Receiver
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
Jul 12, 2009 | Pioneer VSX-454 Receiver
How can I get all 5 of my speakers to work with no remote???
if it dose not have an opion to change specker setup on reciever''then you will need the remote''''
Jan 30, 2009 | Pioneer VSX-D510 Receiver
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Problem with "power off" message
I THINK THERE IS A MOISTURE IN YOUR RECEVER KEEP RECEVER IN SUN LIGHT FOR 5 OR 6 HOUR
Aug 21, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX-D510 Receiver Logo
959 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
