Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canonmp830 have had printer for 1 year and have had no problems, it will not power up at all, have checked wall socket and printer cable and plugged printer into another wall socket,and still no power, power did go off for a while a week ago but no other appliances have been affected, printer is plugged directly into power board with all other pc appliances??
    Genius:
  • 2,985 Answers
Have you checked the fuse[s]? You don't mention your location so I cannot comment of what protection devices that may be involved. UK has fused 13amp wall plugs for example.
Posted on Aug 21, 2007
  • 4 Answers
I just had the same thing happen to me. There was a lightning storm here on Saturday night so, even though I have a surge protector, I assume that it took a surge. HERE IS THE SOLUTION! If you unplug the printer (pull the plug!) for at least 20 minutes (which lets the system discharge)then plug it back in, the system is allowed to reset and will fire back up when you press the power button.
Posted on Aug 27, 2007
SOURCE:
My Lexmark X5630 does not switch on, what can I do?
1 Press to turn the printer off. 2 Disconnect the power cord from the wall outlet. 3 Gently remove the power supply from the printer. 4 Reconnect the power supply to the printer. 5 Plug the power cord into the wall outlet. 6 Press to turn the printer on.
Make sure the cord on the back of the printer is pushed all the way into the socket, it should only fit one way. If that fails, check that there is power at the outlet you are using.
Sep 08, 2017 | Lexmark Office Equipment & Supplies
MP750 Printer does not power on. There were no evident problems, was printing well one day and the next would not urn on.
1-check the power cable if it is twisted from both sides. or buy new power be sure it is inserted nicely into the printer socke.t
2- check the plug if there is any fuse! if it is blown up., change the fuse with the same amp rate.
3-check power source socket...try another power source wall socket.
4-keep long press on the power on.
I hope will do....otherwise something went wrong with your internal power supply good luck.
Aug 14, 2013 | Canon PIXMA MP750 All-In-One InkJet...
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
I Purchased new ink and installed it twice Black and Cyan and a message say the catridges are empty. Is there something I can do?
Step 1: Reset the printer
CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
Check the printer for the error message. If the error message still displays, go to the next step.
Step 2: Semi full reset
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord.
Jun 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer error
Apr 22, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer won't start
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
Mar 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
My Officejet 6310xi All-in-one keeps going to power reset also. I went to hp.com and followed the recommended troubleshooting steps there. I also used the directions to reset the printer to factory...
Hi. I just got off of the phone with an HP case manager. I was ready for a refund, but he helped me and now my printer is working fine. The key is to have your Officejet 6310 plugged directly into a wall socket. The variations of power through a surge protector often cause a power shortage to the unit. The 6310 needs the 110 volts to operate. Surge protectors will sometimes rob the unit of this power. Follow these steps:
1. Unplug the power cable & ethernet/usb cable from the unit (stand alone mode). Let it sit for a minute.
2. Plug the power cable directly into a wall socket. Then plug the power cable into the 6310.
3. After it powers up, push the "Setup" button.
4. Right arrow to "2.Print Report."
5. Press "OK" button.
6. Right arrow to "4.Self-Test Report."
7. Press "OK" button.
A page should print showing alignment and color settings. Now you're back in business!
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Power
hi,
try this
> connect the power chord directly to the wall socket.
> check with different wall sockets.
> unplug and plug in back the power chord. make sure that it is securely plugged in.
> check whether there is a light on the box which comes between the printer and the wall socket.
> if there is light and you hav the problem u need to service the unit else power chord may be the problem.
thanks and regards
agnel
Feb 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
174 people viewed this question
Clive
Clive
old marine
old marine
