Please follow the below procedure to set the regional settings of your choice on your Philips DVD player:
Step 1: Turn on your DVD player (without disk)
Step 2: Press "Setup" from the remote
Step 3: Go to the "Preferences"
Step 4: Enter "138931" and the current zone will displayed
Step 5: Use the Up and Down arrows to change area (0 = multi-zone)
Step 6: Press "¨Play" on the remote.
Or you can use Leawo Blu-ray Copy to make the Blu-ray/DVD disc to region-free, so that you can play it with any Blu-ray player or computer. It is one of the best Blu-ray copy software to copy and back up Blu-ray/DVD/ISO files to hard drive or blank Blu-ray/DVD disc. This Blu-ray Copy software could help preserve your Blu-ray/DVD discs and keep them away from damages. It could copy and back up Blu-ray/DVD disc to computer in folder and/or as an ISO file, or back up Blu-ray/DVD disc to blank discs in 1:1 rate.
Source: https://ccm.net/faq/3767-how-remove-regional-lock-on-a-philips-dvd-player
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVDR3475/37 Recorder
Your device is designed for playing back region 1. It will also playback disks recorded with a region setting of all. The region setting of the device is fixed. Also it will only playback NTSC, and not PAL . This is also fixed on your unit. Sorry I could not bring you better news. However there are many burning and conversion programs you can use on your computer (ie Nero Vision, ConvertXtoDvd,..) which provide you the optional settings you are looking for, and allow you to burn in the setting you choose, allowing for playback on your Philips device. Good Luck!
SOURCE: Convert DVD Player to all regions
I found solution: Go to Google and type - DVD help. There is a site with codes for DVD players. http://www.videohelp.com/dvdhacks/philips-dvp-3260/9309
Just type in the codes by: Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number.
Press "OK"
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
SOURCE: Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
Region
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
