Question about Sansui DTV2760 27" TV
Tv i bought a new xbox 360 how can i get my tv to switch to the correct input to play it?
    Genius:
  • 1,153 Answers
Do you have original remote if so, look for input, aux, or source to switch back and forth. If no remote look for same on set. SOme set you can plug xbox in and reprogram and it will pick up signal and program it for you.
Posted on Aug 25, 2007
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
My sounds works and so does my directtv but no picture will show up for my 360 i bought a new av cord and it still wont work how do i fix it
Are you on the correct channel or input for the xbox 360? Also check your av cable to see if it is on the hdtv or regular tv. You can move the switch to make the adjustment. It may be how you have set up your xbox 360 cables and the directv box cables to the tv so you should consult your tv manufactory for the correct guide on setup.
Dec 22, 2010 | Microsoft Xbox 360 Console
Xbox 360 sound but no picture can any one help
If you've just bought your xbox 360, then you probably haven't got a HDMI cable.
Which I think you could need.
Aug 18, 2009 | Microsoft Xbox 360 Console
My xbox 360 picture is not showing up it has sound
make sure the tv input is correct, make sure that it's plugged in correctly, and some times the 360 just freezes.
Aug 16, 2009 | Microsoft Xbox 360 Console
New HDTV.. xbox 360 has no audio but has video
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
Jun 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays sound but no the video
try another tv to ensure its your xbox and not tv input. also look on your av cord there is a small switch on it make sure it is in the proper position hd or tv.
May 01, 2009 | Microsoft Xbox 360 Console
Hi I have just bought an Xbox 360 and connot get
try switching the av cord to "tv" instead of "hdtv" and also make sure you are selecting the right input on the tv's settings. Indeed if you try it on another tv and it has the same problem, I would take it back for a replacement, or fix it yourself. If it is hardware related, then try Team HYBRID's Ultimate X-clamp Fix but most likely you just have something set up wrong with your wires.
Feb 28, 2009 | Microsoft Xbox 360 Console
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
Help with getting to video
TRY THE SAMSUNG CODES for any universal remote
Oct 15, 2007 | ESA EF402E 20" TV
Sansui DTV2760 27" TV Logo
188 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
