Question about Samsung Blackjack SGH-I607 Smartphone
Samsung Blackjack The phone turned off and will not turn back on or even take a charge
    Sergeant:
  • 279 Answers
Did it last shut down after draining the entire battery? And are you trying to charge it through a USB connection? The USB charger only charges the phone if it's on (I know, that's stupid, but there you have it). You'll have to use a power inverter and charge it on a wall outlet if the battery is dead. If that's what you're doing, let me know and I'll try to find another solution for you.
Posted on Aug 31, 2007
SOURCE:
My blackjack will not turn on
Please try to power cycle your Samsung BlackJack. Please remove the backlid and remove the battery. Now plug in the charger and after that the battery. Now leave this phone for approx 1 hour. Now try to turn it on.
I hope this helps but if does not even help you need to contact Samsung for a repair.
Please do rate my solution.
Regards, Rashid.
Oct 28, 2009 | Samsung BlackJack II Smartphone
Phone will not charge.
Return to the carrier for warranty repair.
The charge port of the Blackjack starts to go bad and will not send the full charge tot the battery.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Jun 13, 2009 | Samsung BlackJack II Smartphone
Beeping while charging.
one the top left where you turn down your speaker volume when off the phone turn that all the way down but it will also turn down your ringtone if im right
Feb 20, 2009 | Samsung Blackjack SGH-I607 Smartphone
BlackJack II will not charge!
This is a case of return to to store. It should be covered under warranty as it is a defect with the phone
Dec 25, 2008 | Samsung BlackJack II Smartphone
Blackjack phone
One of the posible things is that the battery is no good. This can simply be fixed by bringing it to your carrier.
Sep 24, 2008 | Samsung Blackjack SGH-I607 Smartphone
Phone turned off and won't turn back on phone off
Charge the battery.. just in case.
then go to http://www.essistme.com/2007/07/31/samsung-blackjack-tip-how-to-perform-a-hard-master-reset/
Sep 20, 2008 | Samsung Blackjack SGH-I607 Smartphone
My samsung blackjack 2 will not charge. the battery is now totally dead, will not turn on and will not charge even with the wall outlet charger or the computer usb charger. when the phone still had some...
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Jun 09, 2008 | Samsung BlackJack II Smartphone
Blackjack phone setting wont turn on
Scroll down to where it says phone off. Then hit OK or the middle button on the fromt side circle. Go to turn phone on. Wala...if that does not work try selecting your network from the -start-settings-phone options- network-then select your network
Apr 24, 2008 | Samsung Blackjack SGH-I607 Smartphone
Blackjack won't turn on
THe BlackJack phone will only charge while its turned on! If you allow it to go totally dead you cannot recharge it. You will have to get a new battery.
Jan 12, 2008 | Samsung Blackjack SGH-I607 Smartphone
Blackjack will not power up even after charging battery
the pins inside the phone where its plugged in could be messed up, that's whats wrong with mine but i found the phone and i don't have warranty or service for it, basically use it for storing info.
Aug 21, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung Blackjack SGH-I607 Smartphone Logo
79 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
