Question about Sharp 27J-S100 TV
Tv comes on for a second, then goes off.....
My Sharp 27J-S100 TV will come on for a moment and then go off. If you leave it plugged in it will not come back on at all, but if you unplug it for a short period then plug it back in, it will come on again for a second or two and then go off. I'm a technician on copiers so I know there is something that is coding out inside. PLease tell me how I can get to the service mode and how to pull codes so that I can more effectively converse with a TV repairman. Thanks in advance for any help you may be able to provide.
  • Anonymous Mar 29, 2009
    I have the same problem, but I can't even get the service codes to come on. Is there anything I can do to fix this myself or just take it in to a repairman?
  • 67 Answers
To enter the service mode . while pressing the vol-up and ch-up buttons at once, plug the AC cord into the wall socket and switch on the main power . now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
Posted on Sep 19, 2007
SOURCE:
Tuner not working and its good all the voltages are there
could be but this is not a extremely expensive set, Sometimes the tuner if bad has bad solder connections on the board INSIDE the tuner, most that do will react to being banged on with set on and signal hooked up, a replacement tuner if available would be rather costly, doe the set have audio/video input jacks on it?
Dec 15, 2012 | Sharp 27J-S100 TV
Problem with degaussing coil locking out main control
Check the degaussing posistor. Replace it with a new on of same type. There are so many types of this component. Might look like these.
Jul 03, 2012 | Sharp 27J-S100 TV
Sharp 27J-S100 How to adjust contrast??
There are actually two adjustment access holes (focus and contrast) on the back of that model. Here is a makeshift map...
On the back of the set mentally divide it to a left and right half. About the middle of the right half and around 4 or 5 inches up from the bench there will be two 1/8" holes. one on top of the other and about 2" apart. Slip a "pocket" sized flat head screwdriver into the lower hole and feel for the blade to enter the slot and gently turn either direction to adjust the contrast to your liking. The other hole above the "contrast" hole is for "focus" and really should be left alone.
The entire back cover can be removed by taking the four screws out of the corners and slipping it off. Then you can actually see the adjustment controls if you find getting that little screwdriver into the hole would be easier with it's clothes off...
*he smiles...*
Dec 16, 2011 | Sharp 27J-S100 TV
Want to see a free online manual for the Sharp 27J-S100 CRT TV--need to know what is the best possible hook-up (HDMI, Component, S-Video, or Composite) for pic quality. Thanks!
CRT-(Tube tv).Dosen't support HDMI cables.S-Video cable.Only on some a 27' and above.Mostly are R,Y,W RCA component cable support work best for the standard below 27" (CRT-tube-tv).
Dec 17, 2010 | Sharp Televison & Video
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
The TV will shut off after a few minutes and then cannot be turned back on until you unplug and replug it. Then it will shut off again after a few minutes. How can I fix that? How much would a repair...
it sounds to me that there is a bad capacitor or perhaps a cold solder joint somewhere in the power section of your tv. not sure how much repair would cost, but i will say it's about $50 to have an service tech come out and lok at it.
Aug 08, 2010 | Sharp 27J-S100 TV
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
Need a new remote
A Phillips universal remote will work. Just program it for the TV Model. These are about $15 at Radio Shack.
Mar 01, 2009 | Sharp 27J-S100 TV
Picture converges to the center -- "funnel" like
1) Solder any / all bad connections
2)troubleshoot,locate and replace any bad parts in pincushion
circuit....start with pin amp output.......
3)No problem found ?.........could be bad yoke.................T.
Dec 21, 2007 | Sharp 27J-S100 TV
Adding Audio Output to TV
headphone jack is perfect. Buy ( radio shack, ebay,home depot,best buy ) the mini plug to rca breakout cable and once you plug it in it should mute speakers. Otherwise go into menu, audio, and usually there is a selection to cut off speakers
Dec 03, 2017 | Sharp 27J-S260 TV
Televison & Video Logo
169 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
