This problem should be removed because:
Problem with Bicycle Accessories
lost manual to Bell wireless bicycle computer
need instructions to reset computer
Solutions (5)
Best Solution
road bike
20 1596
22 1759
24 1916
26 2073
27/700c 2124
mountain bike
24 1888
26 2045
27 2155
28 2237
I hope this helps to reset the computer
Here are some things the book doesn't tell you:
You have to completely reset the speedometer and lose your odometer to reset the MPH. Hold both buttons for 3 secs to get reset. (Remember to use the left button to walk through the setup process and use the right button to change the settings.) First set the wheel size using Ideluna's settings above on this page (right button to change the setting and left button to go to next number). Next is MPH/KPH, after wheel size setting, push left button again and km flashes. Push right button to change the setting to MI. Next is TIME. Push left button and you'll see the time. Hold down left button till 24hr appears. Push right button to change to 12hr. Then push left button to go to flashing hour. Change with right button. Then left button to go to flashing minute. Right button to change minute, hold down to change minutes fast. Now you are set up. Now the process changes, use the right button to walk through the menu and use the left button to reset. Don't push both buttons anymore unless you want to reset everything again. If you want to reset something just hold the left button down until 0. When you are in SCAN mode, push the right button to go to Time, To go back to SCAN once, hold the right button down - It will scan everything once and return to TIME. To go to ODO, push right button once, push again for DST, push again for MXS, push again for AVS, push again for TM, push again for SCAN to stay in SCAN.
I have just bought this model, I can scan the booklet and send it to you. Email> snuffy01@email.com. Ron.
hold down both left and right buttons and everything should light up
how to I reset Bell wireless speedometer to MPH instead of KMH?
Need instruction manual
Please email me the instructions for the Bell F20 Odometer. I've misplaced it. Oops! Lynell Bevels 510.919.0281
computer needs to be set up need instructions
I had the computer fall off the bike and it is showing half readouts. I opened it and removed the battery. still the same results. need the...
how do i change the battery in my sigma sport
how do i change the battery in my sigma sport bicyle odometer
Resetting the distance on my Bell F20 bike...
When I try to reset the distance I press the right and left buttons for 3 seconds as the manual instructs however when I do that it cancels...
i need to reset the computer to reflect a new
i need to reset the computer to reflect a new wheel size but no longer have my instruction sheet. The computer is at least 8 years old
Add Your Solution
Is it possible to get button shifters for an18
Is it possible to get button shifters for an18 speed power climber (made by dynacraft)
how do you remove the bolts from the rear calipers
how to replace the rear brake pads
crosser bike battery powered been lien batters...
crosser bike battery powered been lien batters fine wires fine motor how can you fix motor if you can only been used a...
What cable and adaptor for Tunturi E3 exercise...
It appears to be the cable (with adaptor) that plugs into the bike at the rear, near the back stand. What output should...
Fix-O-Meter
11,673
11,673 people viewed this problem
- 80 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Bicycle Accessory Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
