Question about SanDisk Sansa e250 MP3 Player
Display is breaking up
Everything seems to work correctly as far as music and sound but my display seems to be off. I still see the icons on the screen but they are faded and breaking up. It still has the blue background but it also fading.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
No display on screen and external display
What is your laptop brand and model? No display on either? Does the computer seem like it is up and running, but just no display? Did you reboot when you put the external monitor on the laptop? Maybe you need to hit the FN function key and the corresponding F1 thru F12 key that toggles the display. The correct key will have CRT/LCD on it or it might show the icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 key to show the display.
If all fails, it sounds like your video card in the laptop is bad.
Apr 02, 2012 | Computers & Internet
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Dec 31, 2010 | Bosch Ovens
I have the boss BR-900CD and everything seems to work fine but nothing shows up on the screen. It lights up but no data shows up. Thanks
the problem is from the display IC of your unit. You nee to change the display IC for your unit to display again.
If you cannot do it yourself, maybe you should consult an expert to help you have it fixed.
Good luck.
May 13, 2010 | Music
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
Window display not functioning
You need to use a transformer type voltage convertor.
DO NOT use the type for converting 220 down to 120 for hair driers.
The voltage should NOT be a problem as usually these will operate down to 100 volts. If the keyboard is sounding correctely, that would indicate there is NOT a problem with voltage.
It is LIKELY that the connections to the LCD were damaged in shipping. There are many, many connections to the glass assembly and if dislodged will have lines across the display.
Repairing this is usually not something one can do unless very experience in electronics.
Mar 12, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Lcd display very dim and flickering
I've put up with the same problem on my WD860 for nearly a year. The unit works fine - just the display flickers rapidly, goes very dim or goes off completely (one has to then guess and listen to the beeps to work out what its doing!).
Typically, the fault occurred shortly after the warranty expired. The 5 years parts warranty is a bit of a swizz - as you can only get the parts free if you pay for Hotpoint to fit it.
I did find a place that was offering a new display panel for just over £90.
After much Umming and Arring about ditching the entire machine or gambling on replacing parts (not knowing if it would fix the problem) I Googled the part number "Hotpoint hm0108" and found a place here in the UK (Nottingham) the sells recon parts.
(I won't give the name in case It's classed as advertising). You buy the replacement unit and send your faulty one back to them, which validate their warranty (I guess they recon your part to also sell on).
The display/control unit was just over £40.
Removing the display/panel is dead easy..
- Disconnect the power from the unit (Obviously)
- Remove the 2 screws at the back (from the little brackets). This allows the Lid to be removed. There seems to be a bit of a "knack" to removing the lid - otherwise you break a few little plastic clips!... With both hands push down and back firmly from the front, until the lid slides back about an Inch. Make sure its pushed back as far as it will go before you lift it up - other wise you'll hear the clips break and rattle down inside the unit (Mine did break, but the lid still screws back on fine, so they can't perform any major function!).
- On the display panel pinch the the row of bottom clips all the way along, to release the unit.
- The panel then hinges from the top and slides down and out.
- Remove the data/power Connector block (Which is keyed so that it only fits one way).
Repeat the process in reverse to install the new part.
Everything works a treat. I can now actually see what the unit is displaying!
I've fixed the problem and done my part for the enviroment - by recycling parts that Hotpoint don't make correctly!!... and not had to pay the earth (I think hotpoint wanted nearly £120 for a 2 min job!)... Everyone's a winner!
I have no idea what the actual problem was - obviously a design/manufacture fault with the LCD display unit.
I hope this helps?
(I'll probably never buy anything Hoitpoint again!)
Jul 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Playstation 2 will not display nor play sound
try checking the three coloured plugs in each end of ps2 and tv you noe the red yellow and white plugs make sure they are in the rite order
Apr 24, 2009 | Sony PlayStation 2 (PS2) Console
Hannspree 19" HF199H LCD - Display is LARGE on monitor!
Try Control Panel - Appearance or Display- You can change how your 2nd display looks there.. Sounds like you have it set in Clone mode...(both displays show the same things)...See if you can reset the 2nd display resolution while keeping the laptop in its normal resolution. Not all machines can do this...but most recent ones should be able to.
Mar 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Screen display size on Thinkpad A22p
your system might have damaged the systems video drivers and reverted to legacy.
try to re-install the display drivers again.
if you look in the system/device manager for the display it may just say vga , which can only give you 800x600 native mode.
if you right click on the desktop /properties
advanced /display adapter it should have the name of your video card.
Apr 30, 2008 | Computers & Internet
SanDisk Sansa e250 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
