Question about Samsung RS2630SH Side by Side Refrigerator
Samsung side by side center divider front extremely hot
I have a samsung side by side rs2630sh. I have notice the last few months the center divider of the freezer fridge has been getting increasingly hot and the freezer and fridge have been getting warmer. The fridge was making a sound like a baseball card in spokes of bike wheel, but has stoped i'm not sure that's good or not. Any help that I can get would be greatly appreciated. Thank you sleepyxi.
  • gotamy Aug 09, 2008
    We haven't noticed any problem with the freezer or fridge cooling but the center divider is RED hot. It will burn you if you keep your hand on it. Our's make a noise from time to time as well. Any suggestions?
  • itwiz2000 Aug 09, 2008
    I have exactly the same problem. Any solutions will be greatly appreciated.
  • 291 Answers
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Posted on Aug 21, 2007
SOURCE:
What's your problem?rs2630sh samsung fridge center hot
Do you mean the divider? It's hot to stop the door freezing to it. Nothing to worry about!
May 18, 2012 | Samsung Refrigerators
The center of the fridge where the doors seal is very hot. Took of back cover, coolant lines are extremly hot compressor making buzzing sound.
When you were at the back behind the compressor did ya notice that the fan thier by the compressor was running, what will make that center divider bar very hot (it's normal to be warm) is due to the fan by the compressor not running or the coil also near the compressor being clogged with dust. So check that fan and replace if not running and also be sure to clean that coil free of all the dust ( the coil should be cleaned every 6 months as normal maintiance)
GENE
Oct 04, 2011 | Whirlpool GD5SHAX Side by Side...
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG FRIDGE FROSTING
some heat is normal on the outsides and center divider. how to muche will usually mean the the condesor fan may have stopped working and is unable to cool the condensor coils and compressor.this could cause it to run longer and build up frost
Sep 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge hot to touch
dont run the fridge untill fan is replaced compressor damage will occur if you do.
Jul 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Refrigerator
You have the fan problem. Full the refrigerator out and open the lower back cover you will see you fan is almost become bad. If you apply WD1040 oil you can use it about 3 more months. Then It will die out. I think you better change it now or later on you refrigerator become hot and hotter. If you are careless, you can get burn you skin. I had this problem. Frist, the fan made noise on and off. I applied oil into the motor. It was working about 3 months then I died out. The front end of refrigerator become a heater.
Go to online partstore.com and buy a fan with your fan model.
Dec 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Front between doors is VERY HOT
Had the same problem. I opened the "meat" lever controlling the "hole" between the freezer and fridge compartments (mine is next to the crisper trays at bottom) and put my finger in it to clear any blockage. It's been 24 hours and the center post is no longer hot. Think maybe I had a blockage or the hole was closed off and whatever is in that middle wall needs the cold air flow for cooling. If you discover some other remedy, please let me know.
Dec 29, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
686 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
