Question about Memorex MMP8565 MP3 Player
Need help!!! I pluged it in to the pc, it works, but all a sudden it turned off but wont turn back on. i pull the usb plug out and plug it in but, the pc cant recognize it.I thought it ran out of battery but, plug it in to charge bu tit wont. so i need help please.
  • helperryan Dec 27, 2007
    i have the exact same problem i plugged it in to my computer and it would even read it, its like it wasn't even plugged in and then when i took it out it wouldn't turn back on. what should i do?
I just returned it to the store, got a new one and it did it again..wtf?
Posted on Dec 28, 2007
Will not turn on regardless of plugging it into the charger or the computer
Posted on Sep 20, 2007
  • dobky Sep 20, 2007
    still does not work
SOURCE:
Toshiba satellite p55t-a5202 laptop hibernates then wont turn on
I have had the same problem with my toshiba p55t-a5202 from best buy took it in 2xs then was without a comp for weeks. The 3rd time I just took out 14 screws on bottom(do not loose them) carefully removed bottom cover (push in and up at sides to remove) then found battery. I followed the wires to the middle slightly larger white plug. Then took a very small screw diver and pushed down gently in the flat spot while pulling gently to disconnect the plug. The side lights went out. Then pluged it back in the same way I took it out. I put all screws back on the bottom cover. Pluged it back in and turned it on and whallaa! My lap top was working and I didn't have to be without it for weeks!! I like this comp but will NEVER buy another one with an internal battery. I guess til the next time it not responsive! Ugh! Goodluck!
Oct 07, 2013 | Toshiba Satellite L355D-S7813 Notebook
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Dell inspiron 1525. problem with comstudio virtual adapter... network device im sure base system device. and also usb root hubs all not working missing driver . except one of the usb root hubs are...
Check for spyware. They can stop some USB ports from working. Also. Under system properties and device manager. Scroll down to USB devices. Right click on them and there is an option for. Turning off the power save option.
May 16, 2011 | Computers & Internet
My 32LG350 wont turn on. I just pluged it for the first time i bought it like a month ago. it was working but suddenly it turned off by itself and wont turn on either by pushing the TV on/off boton neither...
Try unplugging the the TV from the power outlet for 30 seconds to a minute and plug back in again. Try to turn on again. Some TV's have to be in a "ready mode" to operate by remote - so besure it is in that mode - or use the power button on the TV.
Apr 01, 2011 | LG 32LD350 32 in. LCD TV
My walkman wont turn on
Not sure if it's the same problem as mine! My battery was ran completly flat and then wouldn't turn on even after being plugged into the computer and hours of it juset sayin 'connecting'. I looked on Sony's website and found this -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
  1. Battery must not be discharged 100%
  2. If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
I bought a usb adapter charger plugged it in and its back to normal!
Jul 28, 2010 | Sony Walkman NWZ-A828 Digital Media Player
My curser disappears for no reason, have to turn
check the batteries in your wireless mouse ?
make shur mouse is still pluged in fully
if on usb hub make shur hub is pluged in completly to ac power and usb main plug in on pc
or plug mouse directly into a usb port if not enough usb ports get a usb to ps/2 converter
buy a new mouse
reinstall driver
uninstall all othere OLD mouse drivers
hope one of those helps best of luck to you
Feb 20, 2010 | E-Machines eMachines Desktop PC
My samsung sch-r450 just keeps vibrating when i try to charge it.
When you plug your usbt cable into your phone and it turns off, leave it off for about 10 seconds witthout the usb pluged into it then power it back on. It should stop vibrating but will need to be charged up with your house charger.
Jul 14, 2009 | Samsung Cell Phones
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
My loaptop aint working at all
Try removing the battery and pulling the power cable then put the battery back in and plug the computer back in and turn it on.
Jan 10, 2009 | Computers & Internet
Problem uploading pictures
Remove any Camera CD software and let Windows try for its self Come back with the result.
Sep 23, 2007 | Fuji FinePix A360 Digital Camera
Memorex MMP8565 MP3 Player Logo
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Tbone41
Level 1 Expert
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
