Question about Toshiba SD R2102 CD-RW/DVD-ROM Burner
I have a DEll Laptop & my Combo Drive Cannot Read Few DVDs'
Hi, i hvae a dell laptop and my combo drive cannot read all the dvd's. only 10% of the DVD's that i buy can be read in the combo drive. i think so there is some problem with the softwares installed...
  • Toshiba Master
  • 12,061 Answers
Re: I have a DEll Laptop & my Combo Drive Cannot Read Few...
This is unlikely to be a software problem unfortunately sry :( From experience I would say the laser/photo quadrant detector in ya Combo is damaged or faulty these Combo drives seem to have this Ahem .. weakness.. The DVD's are fairly easy to replace.. perhaps ya may find one on Ebay?
Posted on Aug 21, 2007
0 characters
3 Points
Dvd drive cant read dvds but can read vcds
First of all, are you trying to read Blu-Ray DVDs? Unless your drive is made for them, it won't be able to. The same may be true if you're trying to read a dual-layer DVD. Not all DVD drives can handle them.
CDs and DVDs need different kinds of laser light to be read, and a combo drive like yours is essentially two drives in one. Sometimes a problem develops in the pickup and it can read one kind of disc and not the other. My experience is that it's usually the DVD function that fails more often. The data on a DVD is much more densely packed and harder to read.
Try making sure the discs you're trying to read are clean. If the problem is affecting all the DVDs you try, replace the drive. New drives for a desktop computer only cost around $20 to $30 and they are easy to change. In a laptop, the drive will be more expensive and maybe hard to find; in that case you may want to consider a USB external burner as a replacement. This is also an option for desktops as well.
May 20, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
DVD writer of DELL Vostro 1400?
if it has a DVDRW drive the yes.........if CDRW/DVD then no.....but it can read dvds
Dec 29, 2009 | Dell Vostro 1400 / Inspiron 1420 - 24X...
Can this drive read dual layer dvds?
I looked up the specs and could not find anywhere in the info that it read or wrote dual layer.
Sep 02, 2009 | Sony Black CRX835E 24x24x24x8 Slim Combo...
DVD not able to write in combo drive
dvd combo drive means that CD's can be Read & Write whereas DVD's are only read , they cant be written with Combo Drive. So if u want to Write DVD then Purchase a DVD writer.
Jul 08, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Apr 20, 2009 | NEC ND-2500A DVD±RW Burner
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Can the lite-on combo sohc-5236v burn DVD-Rs?
A Combo drive is a type of optical drive that combines CD-R/CD-RW recording capability with the ability to read (but not write) DVD media
Lite-on SOHC-5236V is a dvd/cd-rw combo drive so it can read and write CDs and read DVDs (but cannot burn DVDs)
to check the details of this product please click here
Feb 01, 2009 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Dell laptop does not recogize cd/dvd combo dribe
1.Try to update BIOS Firmware
2.Reinstall OS and latest Drivers
Dec 14, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Toshiba SD R2102 CD-RW/DVD-ROM Burner Logo
112 people viewed this question
Top Toshiba CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Cosma Papouis
Cosma Papouis
Are you a Toshiba CD and DVD Burner Expert? Answer questions, earn points and help others
