Question about Ricoh Aficio 2020 All-In-One Laser Printer
Image is rotated
The image being copied is being rotated 90degrees before printing. I am losing half of what im copying
  • 24 Answers
Select the correct paper size by rotating the green paper size selector in front of the papertray.There is two selection for A4 paper.A4 lengthwise and breadthwise.select it correctly
Posted on Aug 30, 2007
After feeding toner, my Ricoh mp 5001giving bad result in coping. How to solve this problem?
remove the toner bottle and make around 50 copies but make the copies in A4 LEF but with open ADF and put a white paper on half of the A4 LEF area for to be the copes half white half black. This must be done for the extra toner that is inside the developer unit to be removed. It must be half black-half white for the machine can print the copies, otherwise it will constantly jams. pit the white paper in the right half section of A4 LEF area and make around 50 copies. But do this without toner bottle inside the machine. After the 50 copies end,print a counter and see does it got better. If is ok then return back the toner bottle and the machine will continue to work. If still the copy is bad then make more copies without toner bottle until the image is clear.
Apr 11, 2018 | Ricoh Office Equipment & Supplies
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
I can't make a copy using the operator's mode. the copy that does print is so light and such small print thatit can hnardlyh be read. Also, the copy that comes oujt is only half of a page. Most of the
It sounds like the settings on your printer in the menu area have been set to reduce the image you want to print? Click on menu and then scroll the features with the up and down arrows and check on the size of the image to print and change it if necessary.
Please clairfy what you mean by "using the operators mode".
Oct 21, 2011 | Dell V305 All-In-One InkJet Printer
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
When copying by putting the original thru the machine, half the copy come out solid black. Putting it on the glass under the lid the copy comes out perfect. Any ideas why this is happening? How can I...
A user default
1.The printer is possibly not designed to perform in color copying through the machine feeder area, only on the photograhic image scan area. Discontinue scanning the image in feed area.
A Technical default
1. The device is nearly out of ink
2. The device printing bands are clogged requires cleaning
A printing material defect
1. The positioning of the medium to be photocopied only achieves success when layed flat on the screen. Possible images are likely when lightening does not escpe in the process.
Consider, using an alternative copy machine that would achieve success.
contact technical expert, soon as possible
Dec 01, 2010 | Canon LaserCLASS 510 Printer
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Xerox 5309 - ghost image on the second half of the print
Has to be a roller problem. First check that the drum is being cleaned properly by the drum blade, it is responsible for cleaning the leftover image of the copy/print before it ( when you remove or look at the drum you should not see an image or toner ,it should be clean , if not replace  drum and blade). Next check that the upper fuser roller is not damaged ( This is the rollers that heat up and fuse the image into the paper  ). If these check out it could be the erase array or laser unit ...Good Luck
May 03, 2009 | Office Equipment & Supplies
AR 5316 VERY DARK BLACK COPIES
You need to check the drum unit for wear or the main charge assembly. If you are not mechanically inclined, just replace the drum unit and clean the transfer charge on the right side door.
Don't forget to rate your answers please.
Jan 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Ricoh aficio 450
hi im jules_09,the average copy life as we call it is 60,000 copies after that you will replace the drum,cleaning blade and the developer.see first if the copy meter is already above 60,000 copies then about the print i think it time for you to replace all that is mentioned
Oct 11, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 2020 All-In-One Laser Printer Logo
126 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
