Question about Brother HL 1440 Laser Printer
Printer crashes PC running XP home ed.
I've installed the drivers and can print the test page that states the printer is properly installed...BUT... every time I hit "print" from a program (MS-Word for example) the PC's uninteruptible power supply beeps (as if power was lost for a half-second) and then the PC just shuts OFF. No shutdown, or anything, just off. The printer then spits out a (usually) blank page. Any ideas would be appreciated!
  • Tony L Aug 21, 2007
    The printer is not connected throught the UPS. It is plugged directly into a wall outlet. That, in part, is what makes this so weird.
    Zt3000 seems to have hit the nail squarely on the head! The beep from the UPS should have been the tipoff for me, but I missed it completely! Thanks!
    Scholar:
  • 76 Answers
With symptoms like that, is the printer power cord plugged into the PC's uninteruptible power supply? NO Laser printer should be connected to a UPS, as the internal heating wand/assembly draws way too many watts, as does the rest of the printer. In this scenario, the PC would shut OFF due to the UPS being momentarily overloaded. Plug the printer into a separate surge protector. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
  • 1 more comment
  • Anonymous Aug 21, 2007
    When was the last time you tested your UPS batteries?
    If the printer is plugged into the same outlet as the UPS, then what can happen is the printer is drawing enough current to cause the UPS to dip, which causes the PC to power off (since the UPS batteries are or nearly are dead).
    Two solutions to this:
    Test the UPS batteries (replace if they don't pass)
    Replace the electrical fuse that powers this outlet. The fuse is in your fuse box, in the basement, the garage, wherever.
    People don't realize that electrical fuses do age, just like people.
    Been there, done that.
    ZT3000
    Correction:
    Let me correct the previous statement.
    "If the printer is plugged into the same outlet as the UPS, then what can happen is the printer is drawing enough current to cause the UPS to dip, which causes the PC to power off (since the UPS batteries are or nearly are dead).
    Why does the PC die, because the UPS batteries are old and the UPS beeps because the electrical fuse is dying too."
    ZT3000
    "Zt3000 seems to have hit the nail squarely on the head!...Thanks!"
    Just doing my job. :-)
SOURCE:
Printer prints test page and direct prints fine but anything sent from the PC only prints (at most) a thin line (about 2cm/1in) on the left side of the page.
Well, if it ran okay with Windows 8.1 until the last month and if it prints a test page ok, the problem is unlikely to be drum wear or wear of internal parts. You sometimes encounter weird streaking effects if the windows are not clean. Normally, if only one side of a page is being printed, parts are worn or the drum need replacing. But your test page prints out. The only thing I can see that would have changed is --Ta da! -- some automatic update by Windows 8.1. Re-installing drivers doesn't really undo any changes in Windows 8.1 itself or whatever you have installed in the last month or so. (Windows 8.1 experts can stop laughing--I am simply making an educated guess.)
If this were a home setup rather than a work computer, I might see what would happen if I returned the computer to a state prior to "the last month or so." If the printer then worked, you would know it was not a hardware problem but rather what had been installed on the computer after that. Is the printer actually using the Brother driver or is it deferring to a Microsoft driver? Just something for you to check in your device manager. If returning the computer to a former state fixes the problem, you may have to test subsequent installations to determine which one troubles the printer, a tedious process unless a candidate springs to mind.
Aug 11, 2015 | Brother HL-4040CN Laser Printer
Can't install printers.
Two reasons why this would come up. One the drivers are Win 7 compatible. The other is your user account does not have enough access rights.
Dec 27, 2012 | HP Photosmart C410a Premium Fax Wireless...
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
Printer stuck on pending
It sounds like the message to me that the printer and the pc are not communicating very well and when you went to print your 54 page document your printer could not handle such a big file there is a communication error between them both. have you updated your printer drivers ? have you run a virus scan on the document ? you might have a virus in one of the drivers for your printer ! what I would do is uninstall your printer from your pc go to add & remove programs remove your printer and then go to the HP website and fully download your software again for your printer when you go on to the HP website type in your printer model number and ask for a set up disk for your printer so just type in instalation disk for
HP Deskjet F390 it will cost you nothing this website will make sure you get everything you need to fully install your drivers back into your pc and any updates that you are missing hope that helps
Cheers
Jun 09, 2009 | HP DeskJet F380 All-In-One Printer
Network printing: can print test page, but not from apps (Word, F
Turn off advanced printing options under the printer's preferences or download updated driver from HP website.
May 28, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer will not install on vista operated computer
pardon me for asking if you have downloaded the driver for Vista? pls ensure that you have done this otherwise it will not really print becuse of incompatible drivers.
or pls check if there is already a presence of a printer in your computer, then right click the proprties and hit test page.
Dec 04, 2008 | Office Equipment & Supplies
Net Gear PS121 print server, prints test page but not word docs
It's a driver problem not installed properly on the XP machines. Here's what you can do. Install first the driver of the printer directly to the XP machines. Then try to re-do the smart wizard installation.
Dec 02, 2008 | NetGear WGR614 Router
Sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Nov 05, 2008 | Sharp AL-1642CS Copier
Brother HL 1440 Laser Printer Logo
94 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
