Starts fine, driving down the road it tries to and sometimes dies on me,then when i let it sit awhile it will start right up, and i'm on the road until the next time it does the same thing over again.
SOURCE: 1998 Honda Accord 4 cylinder - Electrical? CAR DIES.
Hi..
The first step I recomend for try to fix your car is:
Get the car Scanned for see if there any present CODE.
The code help to have IDEA where or what is the problem.
If you don't want to spend money,
Go to ADVANCE Autoparts, Auto zone autoparts and some of the NAPA's Autopart, they make Computer diagnostic with out charge for that is only a free service.
If they don't found any code. I RECOMEND
Replace the FUEL PUMP Realy. "(MAIN RELAY)."
Because is one of the 90% of the problem with shutdown or non starting conditions.
The relay is located under the left side of the dash. The relay
Is bigger than a regular relay. colour gray. You can get at any autoparts.
OK... I hope this help to start diagnostic your car.
Thank you for use fixya.
SOURCE: dies and has trouble starting.
need to have the alternator tested sounds like a bad voltage regulator.
SOURCE: When i start the car
My friend, you seem to have fuel problems. the honda have an electric fuel pump inside the gas tank. it maybe old and does not develop enough fuel to the injectors that explains why it conks out.
first replace the fuel filter, it maybe clogged that fuel cannot flow anymore. if it still conks.
check the fuel pressure at the fuel filter it should develop 32psi or more. otherwise, replace the fuel pump.
the worse is that your injectors are contaminated with FOD, you have to replace the 4 injectors.
SOURCE: 93 honda civic ex sputtered and died while driving
Is there any white smoke coming out the exhaust? Sounds like the same problem my friend had when he warped his head on his 91 civic. Any overheating at all? Otherwise another guess would be maybe a bad catalitic converter that clogged up. Hope this helps any, good luck
SOURCE: 2000 Honda Passport wont start.
I ended up finding a repair shop here in Cleveland. The problem ended up being a short in the electrical system. My fuse kept blowing. That's why it wouldn't restart. If you decide to take your vehicle to a repair shop, have them check out the electrical system. My problem was found under the drivers side fender. Some of the wires were corroded. Good luck!
