Home | IBM | ThinkPad T41 PC Notebook | My IBM T41 thinkpad mon...
IBM ThinkPad T41 PC Notebook
Problem for IBM ThinkPad T41 PC Notebook
My IBM T41 thinkpad monitors goes.
By jovi82466 on Mar 23, 2009
My thinkpad monitor is going out. When the laptop is moved of if the left corner is hit, or has a little pressure is put on it the screen will go out , or the screen will start having lines in it. Also the cursor will have a box around it and it will move where ever the cursor goes. I hooked the lap top to another monitor and the other monitor done the samething.
Best Solution
posted on Mar 24, 2009
Helpful)
joshebrum
Rank: Apprentice
Rating: 92%, 4 votes
I have the exact same laptop and issue with the screen going out or locking up (w/the lines as you described). Here's the bad news... this started happening to mine a few weeks ago and I had a few different people weigh-in on the situation (locally) including one person who examined the inside. Unfortunately (unless you can find an obvious loose connection/wire) it IS likely to be a video card gone bad, and (what's worse is) the video card on the T41 is integrated with the motherboard. Replacement cost (1000+) is, therefore, probably more than the laptop is worth. The other bad news is that it will get progressively worse, so (while you may be able to tolerate it for a while) you'll need to get all of your files off it as soon as possible. Mine will still turn on every once in a while, but is definitely no longer reliable.
Unlikely, but I wonder if this issue is well-documented enough (as a "defect") that IBM would consider a recall.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
Not Helpful)
bobbyspencer
Rank: Wiz
Rating: 77%, 16 votes
sounds like you your video card might be loose or have a bad connection try this power down take the battery out remove the video card and reinstall it but be careful i would not recommend doing it on carpet or anything that can cause static. and if that dont fix it video card might be bad
bob
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Oct 15, 2009
Not Rated)
Shane T
Rank: Apprentice
Rating: 0%, 0 votes
I had the same issue, because of the lose screws on the edges, eventually the small piece on the motherboard got damaged. Believe me I opened my laptop many times and examine the motherboard. I finally found the small and black component's connection which was lose sometimes it works if I push the one side when I turn it on.
Shane
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkPad T41 PC Notebook
Questions and Unsolved Problems for IBM ThinkPad T41 PC Notebook
Do you recommend IBM ThinkPad T41 PC Notebook?
Answer
Answer
I bought used ibm t41 with windows xp pro. I need picture of layout so I know what all keys do.
Answer
Have Thinkpad t41 running XP Professional. Trying to connect to netzero dialup. Get a 633 modem or... (More)
Answer
hello there how to switch the letter key back to letter type
Answer
I am trying to replace my t41 monitor. I need instructions. Can you please help? THanks!
Answer
I had this T41 for 4 years. The only thing I've changed is an additional 512MB memory which was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T41 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
