Question about Zenith TVBR1322 13 in. Combo
Dead br1342z it looks like is dead
    Brigadier General:
  • 6,966 Answers
Hi, By "it looks like is dead", I will assume you mean when plug to the mains, no light indicator and will not power on. If yes, a couple of things you can do to confirm and first aid: 1. Make sure there is power at the outlet/mains. Plug in another electrical device to where the TV was plugged such as lampshade or cell phone charger that will light up/indicate that indeed there is power; 2. Check the AC cord to make sure that there are no breaks, exposed wire, bent plug terminal, soft spot or indications of anything out of the ordinary. If available and possible, replace the cord; 3. Plug the TV to a known good outlet and try powering up, you can also try jarring the TV a bit to shake it up such as a solid thump to the side or to the back would help determine if there is a loose connection or partial open circuit or cold solder; 4. If comfortable doing so, open the back cover and check where the AC wire leads to. Normally there would be a fuse somewhere near it. With the TV unplug, determine if fuse is open or simply replace with a known good fuse of the same rating; 5. Since the back is open, inspect the inside of the TV for any burnt marks, lingering smell of burning or ozone, loose connection or dangling wires. Try the unit again. If all else fails, it may be to your advantage to have a qualified service professional have a look at it with consideration of course for the repair charges for a 13in. Good luck and hope this work out for you or give you an idea. Post back how things stand or should you need further information. Kind regards.
Posted on Aug 21, 2007
SOURCE:
How do i repair gauges on 1995 Isuzu Trooper
post symptoms, we can not guess all the nine ways from sunday
to mess up.
all dead, , one dead, one lies., some dont glow, speed makes noise, or jerks.
the park lamp dimmer is dead>?
do warning lamps work, key, CEL lamps glows?
if not battery is dead, or fuse blown.
the cluster has one fuse, and fues need testing.
fuse that look bad are
fuse that look good, can in fact be bad, (hair cracks)
we use a voltmeter on both sides of fuses. 12v, and 12v.
good,
and the can have 2 or 3 fuses boxes, no didnt look yours up
you can at alldata.com
Dec 22, 2014 | 1995 Isuzu Trooper
Why wont dell i15rv-9762blk wont turn on
Obviously there are no error messages, so it isn't a simple failure.
Several reasons:
1. Dead or damaged battery - look for laptop battery error light or replace battery (borrow a working battery to test)
2. Dead or damaged Power Supply- look for power-on light to confirm operation. Replace PS if dead. (Borrow?)
3. System board failure. No lights/errors messages etc. Place warranty claim.
Aug 10, 2014 | Dell Computers & Internet
Do rat snakes and diamondback rattlers look alike?
Probably a 'hog nosed' snake. About the only one I know of that will play dead. The Eastern hog nose does kinda look like a diamondback at first glance.
Jan 07, 2018 | Televison & Video
Speedometer
is the CEL out? check engine lamp out?
is the odometer dead too.
if you scan the PCM is MPH dead???? look is it.
if not dead, in the OBD2 PID stream then the speedo is bad.
if the OBD2 PID stream shows dead VSS then it is dead.
VSS is veh, speed sensor.
the tool is $9 (USB obd2 scanner)
Jun 24, 2013 | 2005 Honda Pilot
I looks like the master controller is dead. are
It cannot replace, you have to purchase another one.
Jul 24, 2010 | Creative Labs Gigaworks S750 Computer...
3 years old, totally dead dryer
remove the back panel look on the side of the heating element look for a small red button on the thermal fuse push it in.
Also look on the left side by the belt and motor you should see a black piece of plastic with small springs on it push it to the right to reset it if this has tripped,this is a saftey kill switch that gets activated by the drum belt if there if a sudden problem with the belt tension
Mar 15, 2010 | Bosch Nexxt 500 Dryer
Dead on audio or video
If the TV is dead, first place to look will be the power supply, look for 5VDC, 12VDC, and 24VDC at the output connector of the power supply.
Jan 03, 2010 | Element Electronics FLX3220F 32 in. LCD TV
Tvbr1342z dead
Hi again, looks like you posted thrice, here's the link to your other post with my response. http://www.fixya.com/support/t185358-dead_br1342z
Aug 21, 2007 | Zenith TVBR1322 13 in. Combo
Zenith TVBR1322 13 in. Combo Logo
129 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
