unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
If that doesn't work
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
Remove all the cables (composite/component, power, you know, anything that plugs into the console) and let it sit for a minute or so. Plug everything back in. If it still doesn't work, remove the hard drive and attempt to start the xbox. If it works, the problem is with your hard drive. If it doesn't work, the problem is with the xbox itself. Regardless, you'll have to contact xbox customer support to fix either of these problems.
Try using a different outlet, if that doesn't work see if you have another power cable that is the same power as the one on the T.V. and try that. If that doesn't work then there is probably a problem on the board near where the power plugs in. It could be fixed by a firmware update or it may need to actually be repaired.
