Question about Creative Labs ZEN V Plus MP3 Player
Help!! my wmp wont recognise my zen v plus...
I cant get wmp to even sync and my computer tries all the time to install the mtp, but with out luck!! why??? what do i do??? is there some sort of download or drivers i am missing???
    President:
  • 4,402 Answers
· Make sure you have media player 11
· If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
· Download recovery tool off creative's website.
Posted on Dec 13, 2007
SOURCE:
My creative software for Zen Sleek Photo won't load on Vista
Vista by default will support the Zen Sleek Photo as an MTP device, which means that Windows Media Player will recognize it as well as Explorer.
You can use WMP to sync music to it, and Explorer to drag/drop photos to it.
Apr 01, 2009 | Creative Labs ZEN SLEEK MP3 Player
Creative zen touch,
Its took months................. but at last it worked.
1. If WMP 11 is installed, remove it including Media Player 11 runtime
2. Install WMP 10, it must be 10...
3. connect your zen, it will show up as MTP
4. click on your firmware, and at last it showed it was connected.
job done.................... at last
good luck
Aug 24, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
I just buy creative zen stone 1gb
Hey Sheikhea!
You won't need to download or install any programs if you have Windows Media Player on your computer. You can use other programs but WMP is probably the easiest!
  1. Plug in your MP3 player using the USB cord (should be in box)
  2. Open WMP
  3. (If your songs are already in Library skip this step). Click "File" (top left hand corner) then "Add to Library..." Click "OK" WMP will now find all music on your computer and add it to Library.
  4. If the internet is connected WMP will attempt to find song info such as title, artist, album etc. Otherwise right click on song and click "Edit"
  5. Click on "Sync" tab (top of player). A sidebar should appear with "Creative zen.. etc" written on the top.
  6. Drag songs into sidebar.
  7. Click "Start Sync"
  8. The songs will now download onto your MP3 player.
To organise your files into folders etc. go to "My Computer" then "Creative Zen etc" then "Music" and create folders (right click "create folder") copy, paste, and drag your songs in folders as you like.
You can now unplug you MP3 player and turn it on!
Please reply so I can know if this information was helpful or not and can help you further.
Happy MP3ing!
From Kat
Aug 02, 2008 | Creative Labs Zen Stone Plus MP3 Player
My computer dosnt recognise my creative zen microphoto.
http://serviceman.site88.net/index_files/MP3Players.htm
Jun 29, 2008 | Creative Labs Zen Touch MP3 Player
Samsung T10 Mp3 player to be recognised by pc
Heres how I solved this problem
- I was running XP SP2 with WMP10
(Windows Media Player 10)
- Windows will not recognise the T10 unless it has the right MTP (Media transfer Proticol) drivers. This is the little yellow flag you may see on the task bar adter Windows detects the device and trys to install the driver. The drivers are only found in WMP11. Therefore unless you are running WMP 11 your T10 won't sinc or be recognised.
- The Samsung software wont help- so don't bother even installing it as WMP11 has the drivers and does everything the Samsung software does + more.
- I tried to download and install WMP11 directly from the microsoft website but my PC failed the authentcation so I saved the file to my HD instead.
-I then unpacked the WMP11.exe file using WinRAR which i downloaded for free from http://www.download.com/WinRAR/3000-2250_4-10745708.html.
- I individually ran the WMP11 install file and then all of the other unpacked files by double clicking on them (it takes some time). This installed WMP 11
- I then shut down the PC, plugged in My T10 and WMP/windows recognised the T10!
I had a friend who alos did the above but had a couple of problems- he uninstalled WMP10, Installed WMP11 using the WinRAR method above and it didn't work. After uninstalling WMP11 and then reinstalling it again using the WinRAR to un pack it it finally worked after a couple of re boots.
Note: Prior to using the above method i googled and tried several other ways to get the T10 recognised and none worked. From what I can tell you Need WMP 11
Hope this helps
Jun 12, 2008 | Samsung YP-K5 MP3 Player
Creative zen v plus
i had the same problem but solved it, it seems that the usb driver does not always install with the software installation so you must install using the DEVICE MANAGER make sure first your mp3 player is connected, so ( copy & paste) your software to desktop, then go to CONTROL PANEL, then SYSTEM, then HARDWARE then DEVICE MANAGER, in device manager you should see ( zen v plus ) with a yellow question mark above it, which means the drivers are missing, click onto that and follow instructions to install the drivers which you will find in the software you have pasted to desktop. good luck, tony spain
Mar 22, 2008 | Creative Labs ZEN V Plus MP3 Player
No license to play/sync license from PC - Zen Creative V Plus
Start up Window Media player on your computer. Plug your Zen device into the computer. Wait until you see it listing in WMP. Unplug the Zen and see if you can play the songs.
The licenses on the device should be updated by WMP when you plug in the device
Mar 17, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen Touch mp3 player isn't able to play tracks in windows media player 11
im not sure but i think you have to create the playlist first then transfer to mp3
Feb 20, 2008 | Creative Labs Zen Touch MP3 Player
Can't install MTP drivers
As I like MTP mode a lot better than MSC (I can use WinAmp to sync and it doesn't have to restart and refresh its database after disconnecting) I didn't like a lot of the solutions to this and similar problems telling to go to MSC mode.
However, I was able to go into Device Manager (right click on My Computer, click Properties, select "Hardware" tab, click Device Manager) and find the Portable Devices sublist, right click on "Sansa e280" (it had a yellow exclamation point on it) and click install driver. I followed this through, selecting automatic installation for the driver, and presto! Sansa is installed and ready to go. I actually had Windows Media Player open during this process, and while it wouldn't recognize it before, after doing this process, I went back to WMP and it had already found it and was trying to get me to sync it. So if you like MTP, try this. It worked for me.
(Note: this method may not work, unless you tried to plug the player in and it told you that there was an error in setting up the device. My problem was that I had installed WMP 11, but had not done the final "setup" process. After I had run WMP 11 for the first time, I was able to do this successfully).
Feb 06, 2008 | SanDisk Sansa E280 MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
56 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
