Question about Sony CDX-GT210 CD Player
No signal on Radio,
Okay I check all the fuses, the wiring, the antenna, everything is in place but my Radio does not want to get signal. My CD player works and my Aux. for my IPOD works. Everything is checked out. All of a sudden my radio starts to fade and barely gets signal. How can I solve this This is for a CDX-GT210 Sony stereo.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Start with checking the antenna has an earth connection.
Posted on Dec 11, 2017
SOURCE: Installing Sony Explod CDX-GT210 CD deck
try connecting the red and yellow together, and to a 12 volt source. that should deffinately get power to the head unit.
check the fuse under the big connector on the back.
Posted on Oct 14, 2007
shaggyrat
  • 1224 Answers
SOURCE: connect ipod to cd player wit built in aux input.
solution to ipod problem some ipods do not work in directly with after market sterios some do now a good solution is to go to your local radio shack buy the rca jack one end proper male femal connectors on one end then head phone jack on the other this will play anything its just like the old days when you had to buy that clunky tape with head phone jack attachted it works all the time make sure ipod is powered so that it wont loose power while playing its kinda old school stuff but works since most ipod products dont work with aftermarket sterios
Posted on Apr 21, 2008
SOURCE: Barely hear music from ipod when connected in aux Alpine CDA9835
Turn Vol up on i-pod.Go to full,then back a bit. Good luck!
Posted on Mar 13, 2009
  • 227 Answers
SOURCE: aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Posted on Aug 05, 2009
  • 69 Answers
SOURCE: cant find aux conection for ipod function
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Posted on Oct 06, 2009
No audio radio but cd works
Make sure the connection to your antenna is okay or if you actually got a antenna at all. Also check fuses for the audio system. You can find wiring diagrams and position of fuses for your car by searching on google.
May 04, 2013 | Cars & Trucks
I have a 2003 Honda Civic EX coupe. Installed aftermarket radio cd player and the cd works but the radio does not. The issue is not with the new unit as the previous player's radio would not work either....
If you're getting power to the CD player then there's power
to the radio. The antenna involves the grid on the rear window,
an antenna coil and cable to the radio. You can check the
grid for a break and if it's small you're auto parts store will
have a repair kit. My 05 Accord rear window defogger did
not work and it took Honda 2 attempts to repair it. Other
than checking the grid I would bring it to the dealer.
Feb 03, 2011 | 2003 Honda Civic
Radio works fine but power goes off when switch to CD player
Your antenna remote is installed on the amplifier turn on lead.
When your Radio switches source - it thinks the antenna should go down and drops the signal (and thereby dropping the signal to your amplifier).
Swap the 2 "blue" wires and you'll be all set.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2010 | Clarion DXZ-525 CD Player
If antenna is not connected will it turn on
The unit should power up without an antenna. If it powers up then you would only get hash noise on the speakers. You can put a paper clip with a 12" piece of wire to the input or where the ant should go to see if you are getting a signal.
If you have power at the unit then you may have a bad ground (-).
Mike
Jun 28, 2009 | Pioneer DEH-1800 CD Player
2001 Ford Taurus Radio doesn't work but CD player does!
Does your car have an automatic raising and lowering antenna? If it does check your fuses for it. If not pull your radio out of the dash, and check to make sure that the antenna wire has not become lose or unplugged from the back.
Jun 01, 2009 | 2001 Ford Taurus
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
Plays radio not cds
You may have Power antenna and amp remote turn on wires switched. Your system may be looking for turn on signal from radio and only gets it when am or fm is on because power antenna wire is hooked up instead of amp turn on signal.
Jan 18, 2008 | Kenwood Sirius KDC-MP522 CD Player
Power Amp not working When A CD is playing
Hi Cassiel,
You have it wired wrong. The Power Antenna wire is for antenna only. When you go to something other than Radio, the antanna wire signal to turn retract the antennaor turn off your amp. you need to use the Blue wire coming out of your CD player. The intended function of the Blue is remote turn on when every the radio is turned on. This will keep you amp on as long as your Radio is turned on. Change the wires behind the radio from the Power antenna to Blue Remote wire.
Dec 04, 2007 | Sony XPLOD CDX-GT200 CD Player
Sony CDX-GT210 CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
